little john Posted August 4, 2010 Posted August 4, 2010 my a/c goes warm at idle. low side pressure is above the good field on the guage. when i rev the engine, it will start cooling, when i go back to idle, it goes to warm condition.
Jsdirt Posted August 4, 2010 Posted August 4, 2010 Check for debris between the condenser & radiator, & also check to be sure the front of condenser is clean, & fins are reasonably straight. Check the fan clutch -- make sure there is no side to side or up & down play, or any evidence of oil leakage around the shaft. If it's original, replace it anyway, regardless of how it looks. Make sure the shroud is in place & not modified in any way. Same goes for the fan itself - no aftermarket stuff. I'm stuck in a time warp, so if you have no clutch -- just electric fans, then I would check the fans to make sure they are kicking on at the correct temps.
little john Posted August 4, 2010 Author Posted August 4, 2010 Check for debris between the condenser & radiator, & also check to be sure the front of condenser is clean, & fins are reasonably straight. Check the fan clutch -- make sure there is no side to side or up & down play, or any evidence of oil leakage around the shaft. If it's original, replace it anyway, regardless of how it looks. Make sure the shroud is in place & not modified in any way. Same goes for the fan itself - no aftermarket stuff. I'm stuck in a time warp, so if you have no clutch -- just electric fans, then I would check the fans to make sure they are kicking on at the correct temps.
little john Posted August 4, 2010 Author Posted August 4, 2010 Check for debris between the condenser & radiator, & also check to be sure the front of condenser is clean, & fins are reasonably straight. Check the fan clutch -- make sure there is no side to side or up & down play, or any evidence of oil leakage around the shaft. If it's original, replace it anyway, regardless of how it looks. Make sure the shroud is in place & not modified in any way. Same goes for the fan itself - no aftermarket stuff. I'm stuck in a time warp, so if you have no clutch -- just electric fans, then I would check the fans to make sure they are kicking on at the correct temps. i will replace the clutch fan assembly, we've had the truck for 3 1/2 years, doesn't look as if it had ever been changed. thank you, and we'll go from there.
ken1mod Posted August 5, 2010 Posted August 5, 2010 Everything said here is valid although I hate replacing things that are not confirmed bad. I usually run out of money before finding the problem. See my pinned post on a/c advice on full size trucks forum. Ken
