what are good gears and what kind of brand are the best? Where can i get for a reasonable price..
If you intend to change the gear ratio in your axle(s), and your truck is still under the 100k mile powertrain warranty, you must use genuine GM gears to maintain your warranty coverage.
stock 2009 gmc sierra, 5.3L 4 speed? stock gears
Well for stock gears there was a lot of different choices, you need to check the RPO codes.
3.73 & 4.10 gears are great, I got 3.73 gears but thinking of adding 4.10 gears.
RPO codes are:
GU2 = 2.73 Ratio
GU4 = 3.08 Ratio
GU5 = 3.23 Ratio
GU6 = 3.42 Ratio
GT4 = 3.73 Ratio
GT5 = 4.10 Ratio
