Cant Make Up My Mind! 2" Or 2/5" Level Kit
RC 2" or CCM 2."5 kit
-RC 2" easier to install and a little cheaper and a chance it still wont be level
-CCM 2.5" little more work to install and a chance rear will be lower. also little more ware on front end parts. If the rear is lower then i would have to get a taller block for rear to raise it up. which isn't a big deal to me
Any of your thoughts will help. like what do u have and how level is it. My truck has factory spray in bed liner and is going to have a soft bed cover so will have some added weight in rear. Also getting n-fab step bars or another brand like them
My plans is to level these wheels in 20x9 and 33" 275/60r20 tire.
on this truck
I suggest the 2 inch RC level. Alot of people are running them and no complaints. Alot are running the CCM as well but I was never a fan of going more than 2 inches int he front. I mean you pretty much answered your own question. You gave all these cons as to using CCM as well as stating your rear will already be slightly lower because of liner and cover. I'd go with the RC 2 inch.
BTW I like those wheels. Should look sexy
Take measurements, this will make up your mind for you. Make sure you do it between 2 fixed positions (ex. middle of wheel to fender) so the variable of the tire from one side to the other is moot.
On my extended cab like yours my rake is 1.75'' so I plan on installing the 1.5'' Procomp kit leaving .25'' of rake. I'm starting to suspect that the rakes may be different on NBS trucks depending on if they are 4 door, ext cab or reg cab b/c of different weights exerted on the front suspension maybe?
ok in my driveway with half tank of gas i measured and WTF!
LF 36-3/8's RF 37
LR 39-7/8's RR 38-3/4
WTF! truck only has 3500 miles on it. Im hoping its my driveway! I will measure next time im out today in a parking lot
You're right about that. My 2WD RCSB had almost 3.5 inches of factory rake. I've still got quite a bit after my RC 2 inch kit. Just don't want to go above that.
LF 36-3/8's RF 37
Hate to tell you but NO truck sits level. They all sit higher on one side or the other a bit.
Go with the RC 2 inch kit. Much better on your truck, and if your truck still sits a little lower at least you'll have some rake for when you tow.
i really wouldnt mind 2.5" with 3" block in rear! LOL i dont no what i want lol
Do what you think is best for your truck. IMO I wouldn't go over 2 inches. Really I wish I would have gone 1.5 inches. Good luck with your decision.
do u have any good pix of yours from the side? i dont want to much rake! I may just go cheap and easy and put a RC 2" on it!
Not to hijack, but I just measured again for giggles. Front was around 37.25" and rear was almost 40"! This is after a 2 in front level. Almost 5 inches stock rake! Wow I never realized it was that bad on my 2WD. I think I may take out the rear block to help level it out some more.
I had the daystar 2" leveling kit for a while, now I have the CCM 2.5" i like the CCM better, maybe that .5" makes it look better, I don't know. I also have a 3" block in the rear with about .75" of rake. Perfect I think. I've had a lift/leveling kit on here for over 30,000 miles with (knock on wood) no problems at all.
I've been running the CCM kit for 50,000 miles and no problems. I measured the distance from the bottom of the wheel well to the top of my tire and ordered the correct kit that way.
I went with the 2.5" level and didn't put a block in the back. I am glad I didn't because it would be higher but still have the stock rake. I do think that after I buy my wheels and tires I will go with a 4.5" lift though. It seems that the level makes it look better but just isn't really high enough.
    • Thanks, so being a different beast altogether, anyone know what the "optimal" temp is for the 10L80/90 for proper shifting?
    • How many years have I pointed out every point in that link to the folks here and been avalanched with criticisms and outright hostilities at times? I ran counter to even the great CUSTOMBOSS and Lake Speed Jr and the half dozen experts on YouTube and in the final.....GM, Physics (Stribeck) backs that Grumpy old Bear.    Honestly, I never said a thing engineering hadn't studied silly and laid in concrete during WWII. But I'm old, the information is old and yet, the Laws of Physics are eternal.    Okay there is one exception. I vehemently disagree with their use of the word 'tolerances' when what it meant is "clearance".   The clearance is the distance between two objects. The tolerance is the degree of acceptable variation permitted in that clearance. I.E., piston to bore clearance is 0.004" with a tolerance of +/- .0002" so the clearance is in specification if it lies between 0.0038" and 0.0042". Cutting that 'tolerance in half has ZERO impact on lubrication requirements. Makes for more difficulty in manufacturing.  But a tighter clearance 'MAY'. Depends on finish. Anyway....   It's one of those statements made by people to make themselves look smarter than they are to convince people who are as un-enlighten as they seem to manipulate their behaviors. But hey, the blind leading the blind puts them both in the pit.
    • Out and about yesterday on a long Saturday drive I passed a lot of Shell stations. My preferred, so I pay attention. Lot's of small town Illinois so not six stations in three blocks like the city.    Everyone of them over a radius of say 100 miles had regular at $4.19 but one which was the one closest to home at $4.15. However Premium pricing varied greatly between 85 cents over regular to $1.50 over. I'm not counting the price of the station with the lowest regular so the reference is the same for the remainder and all within the same brand. However the spread discrepancy holds across all brands.     @txab, any thoughts on that?
    • What are your thoughts? The Chevy Blazer relaunch was an epic case of 'lunchbag letdown'. Jeep Wranglers and Ford Broncos stick out like a sore thumb.    The AI photos do not look like a 'retro version', but shrunken Tahoes. Get away from the 'futuristic look'. I've seen two concepts. One had rectangular headlight like a Rivian and the other way too big headlights (similar to a previous non-Wrangler SUV) should include dual round headlights like the early version.   If not this would look OK   At least it has GM styling (albeit the K2XX) A lot of the images floating around look like Bronco IIs or the current Bronco. Looking at the Broncos in my area (central Ontario, it seems to be a mix of 2 doors and 4 doors, 'mall rated' to ones that could go offroad.    I'm sure a AT4 and AT4X RPOs could be outfitted similar to a Rubicon if the braintrust understood the whole offroad scene. Crossing my fingers that if it does see the light that the front air dam/bumper doesn't extend below the center line of the tire...
    • I saw this news earlier this year:   https://theautowire.com/2026/06/12/gm-kills-off-chevys-biggest-silverado-trucks-as-sales-collapse-and-factory-fallout-spreads/
