2007 (gmt-900) Gmc Sierra 2500
Well the time has come to sell my 2007 (GMT900) GMC Sierra 2500 HD Extended Cab. I bought it back in the beginning of April and needed it for the summer, now I am looking for another Suburban.
Anyway, here are the details:
  • 49,000 miles (bumper-to-bumper until 55,957 miles or April 2011)
  • 6.0L Engine
  • 6 Speed 6L80E Transmission w/ Manual Mode
  • SLE
  • Z71, 4-wheel drive
  • Remote Start
  • Power Sliding Rear Window
  • Steering Wheel Audio Controls
  • Reverse Sensors
  • Adjustable pedals
  • Integrated Brake Controller
  • Snow Plow Prep Package
  • Brand new 17" rims (literally put on a week ago under warranty)
  • Westin Assist Steps
  • Weathertech Floor Mats
  • GM Plastic Bedliner
  • GM Mud Flaps
  • Tow Mirrors (I also have the standard mirrors that came with it as well)
I am sure I am missing a few items, but that covers the basics. The truck is in great condition. There are a few dings on the rear bumper from the previous owner (senior citizen, truck was too big for him, thus why they sold it). There is a chip on the windshield that happened 2 days after I bought it, its on the passenger side.
I have an Excel spreadsheet documenting the odometer, engine hours, trip and fuel details since I have owned it, and would be glad to forward it along. I average 13.5 exactly MPG, with the best reaching 15.54 MPG.
Always garaged and just waxed again this past weekend.
If you have any questions, just shoot me a PM or email at: [email protected] or message me for my cell. I am located in the Grand Rapids, MI area.
Blue Book is $26,465 in my area. I'll ask that or best offer. Thanks for looking!
- Justin
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
