Tsb Expiration
having bought my nbs 2007 4x4 gmc used, are there any tsb's out on my truck that a dealer would be forced to honor at this late date? and does any one have the tsb # for the power slider cable defect? have looked on safercar.gov and cant find one.
I don't know about the TSB you speak of..but when you go in there with the "forced" attitude you usually don't get far. Dealers are independent owners and will usually work with you but not always...But if there is a TSB it will still be good. Remember TSBs are not recalls. And are you still under warranty.
yea youre right, use the more subtle approach
like a gun or a hammer.......my dealer has never given me anything really for free even the steering shaft
If you want a dealer to work on a TSB.....
If you are under warranty they will fix the problem for free.
If you are out of warranty they will fix the problem and charge you for it.
