1993 Gmc Wont Stay Running
So im new here and need some help with my 1993 gmc k1500 pickup. It wont stay running after it is started. Dies almost immediately. Even if u throttle it, it is very rough like it is missing or has a bad vac leak. The truck has been running good up to now. It was idling in the driveway when it just died and ever since then it wont stay running. I changed the fuel filter cause i hadnt done that since i owned the truck(about 4 years now). I had just changed the oil on it about 2 days before. It is not giving any engine lights and i checked and there are no codes stored. I checked all vac connections going to the tb and if i disconnect the one that goes to the map sensor it starts idling almost normal and i can rev it up and it runs fine? I tried changed the map sensor with one from autozone and it did the same thing so im not sure on that one? I can look in the throttle body while reving it and see fuel spraying so im assuming it has good pressure(also since it runs pretty good with that vac line disconnected). I also changed the iac valve cause when i took it out to inspect it it was very dirty. Though about trying to change the tps sensor just not sure with no codes showing up.. Hope someone can point me in the right direction.
So....you're saying that when you disconnect the map, it idles right then? Then the fix is simple, leave the map disconnected. :rolleyes: It won't hurt a thing, and you'll probably notice better gas mileage and power, but if you have emissions tests, it will not pass.
So....you're saying that when you disconnect the map, it idles right then? Then the fix is simple, leave the map disconnected. :lol: It won't hurt a thing, and you'll probably notice better gas mileage and power, but if you have emissions tests, it will not pass.
:D Agreed.
However it may pass emissions...depends on how they do it. Some of them will put a sniffer up there, if they do that you should be fine, but if they check for codes then you've got problems.
    LonghornMM
    LonghornMM
  • Who's Online   5 Members, 0 Anonymous, 542 Guests (See full list)
    • Because single shot injectors are ancient and multi hole injectors provide smoother running engines and sharper throttle response due to the fuel being atomized better..the best lead I have is a 24lb blue top injector almost everything matches up but the injector will put out about 26lb/hr which is just outside the gm threshold.figured id ask here to see if there was an absolute answer
    • Why is my question?   Any change in injectors requires a tune. Unless you are going back with the OEM part number or a newer part number of that same injector.   Any size difference or type difference like the EV6 style injectors all have different injector data for them. And there is no EV6 injector that matches the factory 25 lb/hr size that your truck comes with. I've been messing with these trucks and tuning them for a long time and what you trying to do doesn't exactly make sense to me.
    • My 6.6 gas lt8 had lifter noise with 28000 miles bought new 2026 and while driven to dealer it threw #1 rod bearing “HD my ass” good luck with yours i hope it don’t turn a rod bearing!
    • When a condition becomes a business model.    https://www.gm-trucks.com/gm-truck-suv-incentives-pricing-2026/   Zane posted this in "Latest Articles".    The honest bottom line   Truck buyers have spent three years assuming this is a temporary condition that will break once inventories normalize. GM just presented it to investors as a durable strategy, on a chart, as evidence of good management.   Inventory did normalize. GM is at 511,000 units and squarely inside its own 50 to 60 day target. The discounts still did not come back, because the low incentive number is the goal rather than a symptom of shortage.   Plan your purchase around that reality instead of waiting for it to change. Follow our ongoing GM News coverage for pricing and incentive changes as the next-generation trucks land.
    • Thought it was raining this morning when we woke. Nope. Dew point was over 80 F and humidity 98%. Zero visibility distance. Everything was 'sweating'. I've seen rain come out of clouds but never out of Pepper or the tree trunks.    Wicked storms just missed us sliding off to the east but by blocks. Heat index about 110 F with air temp in the 90's.    This is  our third wave this month of multiple days of this type of weather. And yet the grass is going dormant and the ground is cracking this side of the street and water up the the hood opposite. Just weird stuff going on.
