Dead Dmax
Zumwalt
About two weeks ago my 2006 dmax after I shut it down, it would turn over however it didn’t seam to be getting any fuel, 103 deg day. I let cool over night and it started up like nothing was wrong. Now the truck dies while leaving a parking lot, same symptoms however it won’t start even cool now. 95 deg day, I’m suspicious of the fuel delivery? No codes other than glow plug #5 have been on for some time. Fail safe?
I would say you have a leak at the fuel filter. If you prime it until fuel runs out of the bleed screw will it start and run for a bit? If so, I would change your filter and check for messed up O-rings on the filter and the WIF sensor.
