Chattering Noise From 5.3
I have a 06 w/ 5.3 I only get this every now and then, but when i accelerate hard where my RPM's are in the 4-5k range I will hear a chattering almost like a grinding teeth sound coming from my engine... I feel no lose of power , no codes , temp is fine , oil level good , it just happens random. My truck has about 39k on it now , and mechanically it has been great ! I run royal purple it it so i know it has great lubrication. I just hope this noise isnt a start to a big issue.
I average 13.7 mpg , so everything seems to be in line... Any ideas?
It sort of sounds like you might be getting spark knock. Could be from some bad gas. I see you have a 93 octane tune. Your ignition timing might need to be backed down a tad.
you know, i have heard something similar on mine. I have the 93 tune also. When I used to have a '97 vette with the LS1 engine, I could hear noise similar, and I thought it was the valves or pre ignition. Turned out it was the injectors. They really are that loud. SO, i think our engines may just have loud injectors like the vette did.
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
