Nbs Rims On Obs?
90'rado
Hi everyone, new guy here, I have a question that pertains to swapping NBS rims onto an OBS.
Here's some quick background info: My truck is a 1990 RCSB Silverado. It was my first vehicle and I've made several improvements to it over the years. The truck sports a warmed over 350 that I built a few years back. It's nothing crazy, but just a good stoplight bruiser. It's bored .060", I ported and polished the heads, enlarged and relieved the oil return holes in the lifter valley of the block to go with the high volume oil pump that I also used, it has headers and dual 3" exhaust with balance pipe, I burn my own chips to tune the ECM, it has a mild cam that is still considerably bigger than the stock cam, I modified the throttle body with the ultimate TBI mods to increase breathing capabilities at higher RPMs, I've installed an E-fan, the truck has the "salad bowl mod", and there are countless other small things that I can't remember.
3 years ago, I rebuilt the 700R4 just for the hell of it, but still ended up swapping the A4 out for a M6 (T56). The T56 has a PRO 5.0 Short throw shifter with a billet aluminum pistol grip handle to stir the gears quickly. To go with the hopped up 350 and the T56, I recently completed a 14 bolt SF swap.
Now that I've swapped in a 9.5" 14 bolt that is 6 lug, I'm planning on swapping on some C2500 front rotors which are 6 lug and will bolt right up to my 2WD spindles giving me the same 6 lug bolt pattern all around.
So here is my question, I've got a lead on these wheels and tires from a NBS, I'm not sure yet if they're from a 4x4 or what, but I'm investigating. What I would like to know is can I use these wheels on my OBS truck? Remember, even though it is a half ton 2WD, my truck is going to be 6 lug all around since it has a 14 bolt 6 lug rear axle right now, and I'm planning on swapping the front 5 lug rotors out for the Light Duty C2500 front rotors.
I had those wheels with chevy centers on my '95 silverado Z71. So if the bolt patterns will match up I see no problem. My wheels were off of a 2000 2WD that I threw on.
    Greg3160
    Greg3160
  • Who's Online   1 Member, 0 Anonymous, 438 Guests (See full list)
    • Late reply, but yes—it works on the SLT trim. Compatibility comes down to the plastic shroud shape behind your mirror, not the trim badge itself. On the SLT with auto-dimming, it uses a plug-and-play Y-harness off the mirror/rain sensor power, so no need to run wires down to the OBD port. If anyone's ever unsure about fitment, just drop a photo of your mirror housing and we can double-check it.   Appreciate the detailed feedback on the install! On the windshield glare—we actually took feedback like yours and developed a dedicated CPL (polarizer) filter to cut down dash reflections on sunny days. If you're still running the cam, shoot me a DM. I'd be happy to send a CPL filter over for you to test out—no charge.
    • There are no stickers in your glovebox?
    • Look at the numbers on the stickers in the door jam...
    • Yes, every time the developer updates his code, you must recompile. I will private message you with the latest because it changes pretty much with every version.
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
