Help Me Find Some Wheels!
sic lsx
ive looked at a ton! i dont like 6 or 12 spoke wheels. i like 5 or 10 spoke mostly, but being 6 lug thats hard to get so i am keeping my options open :cheers: all i came up with
I thought i was set on these i really like them and wanted them, but they have wrong offset :fume:
I looked all over and The one i kind of like but not really, but only other one i think is somewhat ok and are cheap
The sickest ones but cost to much for me! and are the only wheel with a lot of spokes i like
and the stealth novacane
post up what you think!
on this truck
I know it will be torture but I say save and get some BMF's. Their wheels are the most baddass thing out right now.
I'm hoping someday I will be able to save enough for BMF's and a Rancho 4".
Nice ride!
the middle ones i would like. if they were all black! the are half black. Thought about just getting them and untill i lift and dont need to worry about backspacing lol
Nice ride!
^^^THIS
Learn from my mistake man! The only reason I went with the Ultra wheels that I have now was because the Novakanes were about $550 more for the set and that was a huge pill to swallow considering the tires I was getting were expensive too.
So.... for the past 1.5 years i've been wishing I just pulled the trigger and bought the Novakanes. I'm finally making it right and getting the original wheel that I wanted and have always wanted.
Just do it once and do it right (it's tough, i still haven't learned my lesson yet!)
if i get them i will have the stealth nova's!!! I dont get the white :D I mean i can get no problems if i wasnt about to spend 2k for a 9" rear end for my camaro lol I was paling on lifting it after it was paid off. Why i could just run my stockers painted black with some 285's
Like I said... do it right or don't do it at all. Why waste $700-$800 on a set of wheels "just for the time being"? Remember, wheels don't wear out... you have 3 options:
1) stick with your stock ones until you're ready to get what you want
2) waste a few bills on a set of wheels that aren't exactly what you want, but aren't stock so you think they'll make you happy (but wont)
3) buckle down and get the wheels you want now... and guess what, they'll still be there for you when its time to lift your truck. Remember, when you lift your truck you're going to be spending a lot of money---- do you really think you're going to spend even MORE money at that time for the right wheels? I don't think so.
FYI: might have to do some trimming with those BMFs though because they're 9" wide with 5.0" backspace.
    President Roberto
    President Roberto
  • Who's Online   1 Member, 0 Anonymous, 298 Guests (See full list)
