Sluggish Throttle Response On 02 6.0l
I have an 02 gmc sierra 2500 hd with the 6.0L, just recently replaced my garbage bosch spark plugs with ac delcos and now my throttle response is pretty bad. how can i improve it cheaply and what may be wrong?
Have you looked into the fuel system? Fuel filter and fuel pump pressure and pressure regulator?
i am waiting to replace the fuel filter until i run out of gas since i sea foamed it, i changed the oil and the pcv valve that was shot and its still doin it, so i think im going to clean the egr valve next but i can check the fuel pressure when i do the fuel filter, it is only throwing a code when the key is off and my reader says "n/a" which i have no idea what that means
  • 1 month later...
well i checked the fuel pressure and it is fine, have no idea what to do next it is only misfiring when
1.) the engine is warm
2.) it starts misfiring at idle
3.) it goes away when i hold the gas down
any help would be greatly appreciated im very frustrated
    • Just buy the tube and move on with life.
    • Glad that worked, and in this case that is all on Autel for somehow dropping the ball for not updating the GMC section properly.    I believe in the basic section or unless it is in the advanced, when one does a check of lets say individual sensors for what the pressure is ( and it shows a temperature as well ) , I think it picks up on what the model number of the sensor is in a certain section where you choose "OE" sensor or at least mine is telling me what the model number is and matches to what they actually are and that is the number I quoted in a prior post.    I don't recall now if I had said prior that I discovered with my truck anyway that no matter how low I set the placard pressure for the rear tires, if the physical pressure is under 35 psi and I drive it for about 15 miles the pressure warning will come on for one or both rear tires. I am speculating that there is something else in the trucks system that over rides the placard pressure setting once it drops below that minimum pressure to run a metric LT tire at. The weird thing is it does not trigger right away after driving a shorter distance, it took that longer drive for it to trigger. Just something to keep in mind if you were experimenting with pressures below 35 pounds for a tire designed for lower pressures ( larger than stock floatation series tires ) and not being overloaded of course.
    • I've seen a scant few YT vids on them, but it's always in a performance application.
    • No clue. Service advisor said he'd call me this morning, which I'm 99% sure won't happen. They had the truck 5 days, and I didn't hear a peep. Finally had to call them yesterday. I guess they'd be content to just let the truck sit in perpetuity.
    • I had a little bit of time before I left for work this morning, so I plugged the scanner back in, and I selected Chevrolet Silverado instead of GMC Sierra, and the very first option was for a 2026 so I selected that one and I seen at the bottom it had the option for psi change unlike in the 2026 GMC Sierra, I selected that option and it took a little longer than the usual vehicle not supported, and sure enough I got into it, and it let my change the psi values.. I no longer have the low psi warning light!   Thank you for recommending me to try it under Chevrolet instead! I can confirm this device does work for a 2026 GMC Sierra 2500 hd 6.6 diesel  just have to select Chevrolet Silverado instead of GMC Sierra.   Maybe I'll contact Autel and let them know of that issue and maybe they will fix it for the GMC option  because some people probably return the scanner due to it not working under GMC Sierra.
