Corsa Vs Borla
Which one yall got and why did you choose it.
Im debating on one of the two..
What would be the differences...
I know corsa has the RSC but borla doesnt and corsa is 304 but borla just says "austenitic" stainless steel which could mean anything higher or lower than 304.. anyone know what it is.
Anyone hear any drone with borla duel exit, Also any major different sounds with AFM
Corsa FTW. No drone. None, Nada. Best exhaust I have ever owned.
anyone know what type of stainless borla is.. they just say austenitic
anyone that has borla notice any drone?
I think i gatta go borla on this one, i want that dual side exit and found it for reasonable price
Corsa because it's loud outside, quiet inside. :cheers:
haha this is becoming a famous post
wow your famous...lol :crackup:
Borla is 304 and no drone with Borla as well as Corsa. with Borla cat back syatem it is a touring style muffler.No sport style availablefor trucks...at least thats what they tell me...
awesome. thats good to know, i didnt know it was referenced to touring
Borla is a packed muffler like magnaflow. It does not have reflective sound cancellation. I had a GMPP exhaust made by Borla and was not impressed. it had a small amount of drone. At the time they offered a sport and a touring. the only difference was the touring muffler was 4 inches longer.I will keep my Corsa.
Im doing Corsa sport cat back with dualtips on same side... theres a reason why its expensive... Its a great product
corsa sport all the way. best sounding exhaust system out. i have mine matched with stainless long tubes and no cats. sounds amazing and gets really loud when you step on it. no drone inside the cab is a big plus too! well worth the money
    • Thank you.  I really appreciate the well wishes.  I'm an engineer in the telecom industry, I know hardly anything about marketing.  Over the years I did some videos for nonprofits and web sites for small businesses and the seed was planted.  Agree with over-buying, I started shooting on an iPhone before I got my first DSLR and tripod.   I'm looking at trucks with potentially 150,000+ miles to keep the cost of entry low while focusing on the client experience and equipment.  Good wireless mics for interviews, the right lenses & lighting to look professional.  But I don't want to be late or break down, the stress of emptying a trailer & securing a rental truck right before a gig would negate any savings from buying a junker.  So anything that leaks water, has extensive rust, or generally unreliable I'd like to avoid.   Does GM/Chevy overbuild these trucks for upfitting?  I talked to a local upfitter, they sometimes tie lights & other 12V into existing circuits, which I always thought was bad.  Which is why I enjoyed the AUX upfit switches on previous trucks (odd they mostly come with off-road or work truck packages).
    • i guess it might be depending on the type of driving. my 2.7 has 120k miles, changed the plugs at 70k and it runs as good as new. i have not used any injector cleaner
    • GM's are stainless and have a fairly robust powder coating, although, still not worth $850 in my opinion. They will hold up a lot better than their cheaper steel aftermarket counterparts.   What I like about the GM step bars is dealers will often equip their dealer stock with them. Lots of margin. Which means a lot of people end up buying them because they're already on the truck, even if they don't like them. So it's pretty easy to find brand new takeoffs with hardware on Marketplace and Craigslist for about $250.   That's what I did for my crew cab. I wanted ZR2 rock rails for the look, but with the ability to bolt up GM's assist step package. From GM it's about a $2500 accessory all in. The old folks in my life can't get in the truck without steps. I found the whole package on marketplace for $180.
    • I am really glad I found this post and this site... We have a 2022 1500 refresh LTZ that has these problems: - forward collision avoidance warning light - lane keep assist unavailable - adaptive cruise control unavailable   The truck was bought as a new leftover in 2023, so it was still under the 3/36 B to B when it went in for these problems earlier this year. It has been at the dealer on and off now for about 110 days now. These are some of the things they have done that I can read on the service tickets. - replace/add ground straps (4) - check all battery cables and vlts - replace serial data gateway module - replace front view camera - numerous reprogramming - a few calibrations (apparently ending with 'learned') Last week when I had it back the truck had those 3 warnings every time we used it except for 3 times. On three separate occasions the truck started and ran perfectly with no (zero) warning messages or warning lights lit - everything worked perfectly. Over that same time period the truck did not work on every other 'key' cycle which I would estimate at 60+ cycles. On those estimated 57 cycles it had the same 3 problems each and every time.   It is back at the dealer now - can anyone help at all with what the true problem might be?  Or possibly what can be ruled out leaving a lower number of possibilities? Thank you very much for any help you may be able to supply....
    • As for the step bars, friend did just that, bought some cheap ones and we are in Michigan and they turned to rust in less than a year.  In 3 yrs he had to replace one of them because they rusted out from the inside even though he kept after them cleaning and polishing etc. Had to drive 300 miles (to Chicago area) to find a reg cab wt, he ordered one and dealer never got it and with winter approaching (plow truck) he needed fo find one ASAP.  Furd dealer found him one but he choose to drive to get a GMC.    Just what you can expect with cheap stuff, LOW quality.
