Headers On Dynomax Or Flowmaster Exhaust
hey guys im buys pace setter long tube headers with the off-road y pipe. i am also getting dual dynomax ultraflow or dual flowmaster super 4- exhaust both are going to be 1 in 2 out. I was wondering which would be better for hp wise and which would be quieter. I don't want my truck to be to annoying but i want it to be noticed. Thanks hope you guys can help
I have a Flowmaster 40 series setup and it sounds real nice (and it doesn't drone). I'm not sure why sic camaro guy doesn't like them but I just wanted to let you know that I'm very pleased with my system.
ok thanks for the advise i always liked the aggresiveness and sound of flowmaster
i love the flowmaster 40 on my 4.8
i have a super 40 that i simply replaced my stock muffler with and love it. 08 5.3, i also had a flowmaster set up on my 97 z28 and loved it.
Flowdisasters are one of the worse muffler out for drone and power. Yes they make more power then stock but dont make as much power as others. I know ive used them on around 8 truck/cars in passed. They sound good on a old camaro,chevelle,nova with some dumps when u want it loud and not worried about drone in cab. They are a chambered muffler so that kills flow. It has to hit a wall bounce around it and then got out. Magnaflow,dynomax,corsa,borla,gibson all make more power then flowmaster. I used to work at a speed shop and did this for a living b4 i just moved away.we did many catback installs test camaro,tundra,silverado,mustang and flowmaster always made the lowest power and had the most drone.
I cant speak for power, i have no way of testing that and i trust you know what your talking about there.
PS your camaro looks sick. got a page with stats on it?
I also have dual Flowmasters on my 68 Camaro RS and they sound pretty sweet when the 468 BBC comes alive!! The Flowmasters stay at home when I take it to the track, but then they're back on when I drive it on the street. I really like the sound of Flowmasters....just sayin.
Flowdisasters are one of the worse muffler out for drone and power. Yes they make more power then stock but dont make as much power as others. I know ive used them on around 8 truck/cars in passed.They sound good on a old camaro,chevelle,nova with some dumps when u want it loud and not worried about drone in cab . They are a chambered muffler so that kills flow. It has to hit a wall bounce around it and then got out. Magnaflow,dynomax,corsa,borla,gibson all make more power then flowmaster. I used to work at a speed shop and did this for a living b4 i just moved away.we did many catback installs test camaro,tundra,silverado,mustang and flowmaster always made the lowest power and had the most drone.
:confused:
    • Getting greedy...   The AC pump has been replaced at least once per service records, and it's been recharged twice since 2018 or so, in approximately 2 year intervals between those charges.   It was done at the same shop...clearly they were enjoying the revenue of recharging the system periodically versus actually tracking down and fixing the leak. I learned that the owner was 88 years old when she passed in 2023, so maybe they assumed only a temporary fix was needed anyway.   The system is basically empty now, the compressor spins freely, so I'm guessing it "just needs a recharge".   I vacuumed it down, and it has basically held overnight. Doesn't appear to leak under vacuum, check! So it must leak under pressure. I don't have a way to pressurize the system and pressurizing it with shop air wouldn't be great for the air dryer (which is probably toast anyway?)   The dryer (accumulator? I'm not an AC expert) has a Schrader valve, but the high side has an old ball-type valve, which are notorious for leaking. It's clearly had schmutz blown out of it at one point because the line/area next to the valve is coated old black crud, which I assume is AC refrigerant residue/oil, or maybe even dirty dye. I think I'll roll the dice and replace the valves. I have a black light around here somewhere so I'll find it and shine it around the engine bay in the dark to see if there's any dye.   I can't think of another way to track down the leak other than injecting some dye (if it doesn't have any) and having it charged up. We can't buy R134a off the shelf here anymore, so I'll run it up to Jiffy Lube and have them do it. I think I have a coupon. At the very least, the charge should last long enough for a year or two, according to history. I think this truck will be long gone by then. But cold AC is a selling point.
    • Got the truck back today.  Called them yesterday to get an update, and miraculously my truck is finished?!?! The $13k out the door was complete bullshit!  Ended up being over $14k.  They added some bullshit service bulletin that I cant even find, where they replaced my radiator without telling me or asking me, and charging me for it.  Need to do more research into it, cause they leaked the first delivered radiator was ran over by FedEX.  Sounds like bullshit to me. 2.5 Months for an engine swap, which ended up being remanufactured, not new; ****ing ridiculous.  Brakes are squishy as hell, not sure if its from sitting.  Will give a couple days to see it that figures it self out.  GAVE IT BACK TO ME WITH 1 GALLON OF GAS!  Just filled the tank the day before drop off, more bullshit.  My dash cam SD card was formatted, not really much I can do about that. 3 year, 100k GM warranty at least.  Time to sell it and say **** off to GM.  Bad experience.  Cant wait for the survey email to come through.  Overpriced Raptor R, here I come!
    • If I forget the phone in the truck, and forget the truck in the phone, and reconnect.  It works great for the day.  Truck sits overnight, and the next day is a no go.  It will connect Android Auto via usb cable, but not bluetooth.   Ive tried Everything in this thread so far, and nothing works for more than a day.   I think I might have to go to the dealer and have them flash the pcm.   thanks for all the suggestions guys. 👍
    • 2022 2500HD Crew Z71 Duramax single alternator.  Recently had the primary (water pump / fan) belt tensioner pulley bearing to fail while hundreds of miles from home of course the plastic pulley melted and belt shredded which took out some wiring. Found a replacement tensioner assembly and belt to continue now would like to find a replacement for just the pulley and bearing to have a spare assembly in case of a repeat, the rest of the tensioner is fine. Has anybody here found a correct replacement part for just the pulley and bearing? Any help is appreciated.
    • +1 for the 3.0   Perfect for 1500 pickup towing duties.   Perfect engine for a 1500 pickup period. Huge torque at stunningly low RPM makes it feel a lot lighter than it is. The fuel mileage is insane for a tall and heavy 1500... 30+ on the highway. Mid 20's around town.   It's probably not perfect if you bought a 6.2 for the braaaaaaapppppp V8 noises and wrapping it out to 6k. The LZ0 acts and sounds like a small turbo diesel and there's nothing you can do to make a small turbo diesel sound like a big one, and you can't make an inline diesel sound like a V8 diesel/big Duramax. It's a different driving experience altogether.   Drive one, I think you'll like it, though...
