pastorscott Posted September 15, 2010 Posted September 15, 2010 Greetings Had my 04 burb steering shaft repaired like 3 times.. now its back again. Can I just leave it and live with the sound or is there a real danger of my steering shaft breaking one day ? thanks P. Scott
jblakeney Posted September 15, 2010 Posted September 15, 2010 One answer will fix it for good. Borgeson replacement shaft 000937......... It will eventually DRIVE YOU NUTS. Failure of anything is possible. I would not say it is not a safety issue. Sooner or later it will cause a problem possibly, thou closer to later than sooner. Jbo
bcpower66 Posted September 15, 2010 Posted September 15, 2010 My 05 does it every 10-12000 kms or so. Take out the bolt that holds the upper and lower shafts together (under hood), then work the upper half of the shaft in and out to re-distribute the grease in it. Noise will magically go away. Edit: Of course, put the shaft back together and put the bolt back in... I know I shouldn't have to say that but... Brent.
pastorscott Posted September 15, 2010 Author Posted September 15, 2010 Thanks I just did the shaft jerk and WOW it really works !! Noise gone Its free and Its easy ... thanks My 05 does it every 10-12000 kms or so. Take out the bolt that holds the upper and lower shafts together (under hood), then work the upper half of the shaft in and out to re-distribute the grease in it. Noise will magically go away. Edit: Of course, put the shaft back together and put the bolt back in... I know I shouldn't have to say that but... Brent.
desrtrat Posted September 15, 2010 Posted September 15, 2010 Had my 04 burb steering shaft repaired like 3 times.. now its back again. my 03 went thru 4 shafts. the last one installed by the dealer been good for over 20k mi. the lube and jerk will work. i wish they would just put a grease fitting in them and be done with it..
flhusa1 Posted September 15, 2010 Posted September 15, 2010 grease it with this and you never have to mess with it again: green grease
