Torsion Bar Keys.
Hey guys I was thinking of gettin torsion bar keys for my 2007 GMC Sierra Classic. I was wondering if doing this will make my front wheels slant inwards? My friend was telling me that this is the worst way to lift my truck, but I only want 2-3" of lift in the front anyway. Also Would it be a good idea to replace my shocks after doing this?
Yes you are able to crank your torsion bars to get a little lift. I, as well as most other people have installed torsion keys which simply are re-indexed keys to gain a couple inches of lift. No, it will not make your front wheels slant inward. Also, as long as you don't go any higher than 1.5-2 inches then you won't have any problems with parts. Your friend is mistaken. A torsion key lift, better known as a leveling kit, is a perfectly safe and efficient way to gain a few extra inches in the front. As far as the shocks, I recommend new ones. Rough country makes a great kit. I installed one on my truck 2.5 years ago and installed the rough country shocks for 2" of lift as well. I am very happy with this kit and most people on this forum will also tell you rough country is a good way to go. Also, make sure to get an alignment after installing a leveling kit.
http://roughcountry.com/chevy_leveling_kits.html
There are numerous posts on this subject. Don't crank them up over 2" or your ride will suffer. I kept my OEM shocks and the truck rides just the way it did before. I only have 40K on it so far and bought it brand new in July 2005.
+1 Do a search on leveling kit or torsion keys and you will find all the information you need on this subject.
Save your money. Just crank the stock bars about 2", get it re-aligned, and you're good to go. IMO, the keys are a waste of money.
The keys are indeed a waste. They are just re-indexed which allows you to crank even more then you should, causing issues down the road. Just crank the stock keys about 1.5" for the best results.
Heres some threads on the subject:
http://www.gm-trucks.com/forums/index.php?...+bar+adjustment'>http://www.gm-trucks.com/forums/index.php?...+bar+adjustment'>http://www.gm-trucks.com/forums/index.php?...+bar+adjustment'>http://www.gm-trucks.com/forums/index.php?...+bar+adjustment
Use the search. Its been discussed a million times.
