Xm Band?
Hello all, new to the group, and have a quick question.
I Recently purchased a pre-owned 2008 Sierra, and was under the impression that it had XM radio. I even checked the codes in the Glove box, and found the US8 that is supposed to indicate this capability. However, when I tried to switch to the XM Band it does not show up (Using Band Button). All I can get is AM/FM. Maybe I was mistaken on the capability, or maybe I'm stupid, but any light you could shed on this would be greatly appreciated.
Thanks
No Luck with that, says "XM Feature Only" Any other suggestions?
Then you don't have it in that unit.
open the glove box, empty it, look inside toward the top, push up on the little plastic piece that stops the glove box from opening any further. The glove box will open all the way and flip toward the floor (this is ok). now look in the cavity behind the glove box, if you have XM you will see the module with the XM logo on it mounted in there toward the right side. If it's there and the radio isn't detecting it, try checking the wires and antenna wire going to it to see if they came loose.
Haven't had a chance to look at it yet, but assuming it is not there (my luck; Ignorance) can I buy the tuner and put it in to work with the stock radio, and if so, where to look/buy and what is the gm part #?
Thanks in advance.
the tuners are vin locked so they can't be swapped from another truck (so I'm told)
there is a kit to install it to the truck just like factory. Your dealer, GMpartsdirect.com or the XM website can point you in the right direction to get the kit.
    • I don't know how far back vehicles had hour meters, be it driver accessible or diag accessible but was wondering if there was any rule of thumb your shop came up with in regards to an hour limit on engine oil regardless of the miles on the oil.    I know with construction or farm equipment its almost always based on engine hours for maintenance scheduling as no other metric really applies other than a seasonal time limit that one self imposes on items like engine oil.
    • I'm not sure what to say on that mess but I will say that is an odd thing for that mechanic to speculate on as per assuming its been run out of oil a few times as the odds of that engine having instead piled up with a complete seizure would be very high if such events had actually taken place. However there is nothing saying that the oil has ever been changed although once again, what filter was on that engine as that would tell part of the story if its possible to figure out if its a factory installed filter or not. Too many items unknown and a lot of speculation, but regardless of that its one fubared mess that is mind boggling to see for a vehicle that new and its hard to imagine how it ever made it that far in life looking at the top of the engine.    His scanners, I've watched him before here and there and I'd have to say if I recall correctly that some of his scanning equipment is one or two steps up from a child's Exo Sketch 😋
    • I agree. That`s a LOT of sludge for 12,000 miles. I tossed that out here since this is an OCI thread. There`s tons of people here that do not post.   I used to work on a city fleet. That includes police cars and fire trucks. Lesson is, not to only use the odo for oci. A police car has a ton of hours on the engine for the miles it shows. And, not just idling, directing traffic. They beat on these things.   Course, since it is a Kia, they were gonna use the "100,000 mile warranty" for their OCI.😉
    • CLASS ACTION SUITS?  Does anyone know if there is already a class action suit for the paint - which was to have been fixed, changed in after the 2020 GM vehicles?  Does it look like this?    Just started 3 weeks ago - No help from GM as of yet - Dealer will not assist in speaking with GM on my behalf. Confirmed it is the paint they use along with the way the put it on that causes it to fail.  Clearly a Manufacturer's Defect.
    • That dog don't hunt. 😏   First, a 2025 with 12K on the clock AND idled for a year nonstop is false on it's face; this is 2026. You can do one or the other but not both.    Second, ENGINE HOURS are absolutely available. The rest is third grade math. Micky Mouse scanner he got out of a box of Cracker Jacks OR an ID10T error.    Third, if they ran it out of oil "Several times" that motor is boned on the first hit.    Does this guy think piling higher makes it stink less?
