Loss Of Power Under Heavy Acceleration
Hey guys - posting this for a buddy.
He is experiencing a loss of power under heavy acceleration in his 2002 2500 with the DMax. Apparently the truck runs fine under normal conditions, but he has lost the acceleration he expects when he really gets into the pedal. I know he has had a couple of really dirty fuel filters - to the point that he changed gas stations and suspected they had really dirty tanks.
He has had it to a couple of mechanics without any really concrete diagnosis. The last guy told him "An injector pump might fix it" and quoted him 2k or so for the work.
Im not sure I am buying that. Would a faulty injector pump cause this? Any steps we could take to diagnose this ourselves?
  • 3 months later...
Tell him to check his air filter, because if thats the problem, under accelleration the engine isn't getting enough air, and is getting too much fuel. The only other thing i can think of is a partially clogged fuel filter, or bad fuel. I highly doubt its the injector pump, sounds to me that your mechanic just wants to make some extra cash, i have never heard of anybody having injector pump trouble in a D-max. I know a couple of guys with D-max's up here in maine that pull trailers and one of them has over 200k miles on the truck, and they have no trouble at all. Hope this helped good luck. - Brad
  • 4 weeks later...
First thing he needs to have the fuel filter checked for excess vacuum under hard acel. If thats ok, then the fuel pump pressure should be ramped up with the tech 2 scanner to see if it achieves max pressure. If it fails to get max pressure, then your probably looking at replacing all the fuel injectors
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
