2001 Bcm In 1999 Silverado Help
First off I want to thank all the techs that help us out here on this forum. It has helped me out a lot!
I purchased a 1999 Silverado Z71 4x4 Extended cab truck after totaling my 2003 HD Diesel truck.
I could not stand the door locks on this truck so after researching this forum I was pleasently suprised I found all the information to purchase, install, and get the new BCM working.
Now I need to find out if I can program the 2001 BCM so my fog lights will work. Does anyone have any information about this?
Thanks a bunch!
I'd say the dealer will have to do that. They will have to get the program from GM and down load it to their tech 11 and then trans fer it to the BCM. Thats what I have had to do when adding features to my truck that didn't come on it.
Can I ask what was wrong with the door locks that you had to replace the BCM? Thanks.
Travis
Travis
Travis, the doors would lock and then never unlock. They now lock at 24 mph and unlock when I remove the key from the ignition. There was not a way to manually program the door locks on the 1999 BCM.
I am trying to avoid taking it to the dealer if at all possible. Are there any GM Techs out there that know the answer to my question?
Thanks
Thanks
It's been a few years since I worked at a GM dealership, but I'm certain that your door locks could be programmed one of four different ways. The info was never in the owners manual for the '99's, and I think also the '00's, but it was in the '01 owners manual. We were paid to program the door locks for our customers for a time until GM send out updates to the owner's manuals to the owners of these trucks.
If I remember correctly, if you didn't have a Tech II to do it with, you could get into programming by pulling back on the turn signal switch and turning the key on and off a couple of times...I'd have to look it up, for sure, but I'm just certain that it could be done.
Travis
ETA: Jim, just found the thread where you found your info about switching BCM's....now I'm questioning myself, but I'm still 99% sure that 99's could be programmed.
Thanks
Travis
Yes that is true but there were only 2 options. Program for the locks to lock at 24 mph and not unlock, or program so the locks never locked.
I was used to my 2003 truck where they would unlock when it was put in park or the key was removed.
This has totaly gotten off the orignal subject. I now have a 2001 BCM in my 1999 truck and want to get the fog lights to work without having to plunk down 80 bucks for the dealer to spend 10 minutes pulling levers and pushing buttons. Is there a way to program the BCM to get the fog lights to work in a similar fashion the door locks are programmed?
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
