PC builders
MarkD
Does anyone know where I can get a rear panel template for an ATX case?  I am looking for the punched out piece of thin metal that covers the gaps between the mouse/keyboard, USB, serial, parallel, audio outputs.
Thanks :nono:
That one won't work for me.  I need the one that has the mouse and keyboard on top, USB second, then Serial and Parallel under that.
That was the older style I found.  I tried to find someone else that carried one, but ran out of time.  Might be cheaper to visit a compusa or microcenter if available, once you factor in shipping.  Also check some of the case manufactuers to see if you can order one from them.
Here is another site I found, never used them before so bbw.
http://www.atxshields.com/
