5.3l Engine Knock On Accel.
Ridgeback1
My 08' SLT 5.3L 4x4 with 64K has been knocking while under full acceleration(?). I use major brand gas, mixing it up between 87 & 93 Octane. K&N air filter is only engine mods. - and it's clean. Anyone know what could be causing this..? Known problem with this (aluminum block) version of this engine?
Thanks!
i may not be a Gm tech but with what i have experienced when i get a little bit of a knock in the engine it means my oil is nearing the end of it's service life.
so when was the last time you changed your oil??
Could have some carbon build-up.
there is a difference between a knock and a ping. running a lot of 91+ gas will carbon up a motor quicker than 87 due to it's slower burn. at 64k i would do a Sea foam or BG upper engine treatment. also you may have a injector a little dirty and leaning out a cylinder just enough to cause a lean fuel mixture.
good luck
