Cure for 1500HD bouncy butt?
Man the back end of my 2002 Silverado 1500HD bounces a lot. This is not my first truck so I swear the bumpyness is much more pronounced on the HD series. :chevy:
Anyone got a recommendation for smoothing out the ride on a 1500HD? Hopefully something other than sand bags in the bed...  :cheers:
Well the springs on the HD are alot stiffer for loading purposes.If you don't plan on needing the extra GVW you could always pull out a couple leaf springs to get a smoother ride.....Gun
Man the back end of my 2002 Silverado 1500HD bounces a lot. This is not my first truck so I swear the bumpyness is much more pronounced on the HD series. :D
Anyone got a recommendation for smoothing out the ride on a 1500HD? Hopefully something other than sand bags in the bed...  :D
What tire pressures are you running?
You could put a couple hundred pounds of sandbags (or something similar in weight) back by the tailgate, and that will make it ride a little smoother.   :D
On second thought, who cares about the ride?
After seeing Shotgun's pic, I think I am more interested in leveling out the front to rear and getting me some bigger tires.   :thumb:
I was disappointed that my 1500HD rode so rough.  I dropped the rear tire pressure down from 80 psi to 70 psi.  It's marginally better, but It's still pretty rough.  I can feel every little pebble in the road.  Does anyone have any other ideas how to smooth the ride?
WOW!!!  Try 50-55 psi in your tires.  That is what I run in my 2500HD crewcab, and I don't think the ride is too rough...
The owner's manual recommends 80 psi for the rear and 50 in front.  Is that assuming that there's a 2000# load in the bed?
I would only run Max pressure when hauling Max load.  Otherwise you will wear out the centers of your tires.
If you are unladen and have that kind of pressure in your tires you'll see that the outside edges of the tires aren't in contact with the road because the tread on the tires is bulging outward.
I run mine with 60 in the rear and 55 in the fronts. I have done that since I bought the truck except for when I have a load and then I air them up to 80. I have very even wear on them. I bet your ride will be much better if you do this :cheers:
I've always had more air in the front tires to help carry the load of the engine, the bed of the truck is the lightest part of the truck and doen't need higher tire pressure to carry the load.  Just my 2 cents though...
Try these to help the ride when unloaded.  They are mot too expensive (~$200 plus installation) and they won't affect your ability to carry heavy loads.
    • A complete delete is the most thorough mechanical solution, but it is also major engine work. On a quiet truck that is still under extended warranty, opening the engine purely as prevention is difficult to justify. A plug-in disabler stops commanded cylinder deactivation, but it does not remove or repair the collapsible lifters, so it should not be treated as failure insurance. I would keep the oil full, document the maintenance, and have any persistent tick, misfire, or loss of power diagnosed promptly. If the engine eventually has to come apart, that is the logical time to compare an OEM-style repair with a complete delete. The right choice depends on the truck’s symptoms, warranty status, expected ownership period, and whether the engine already needs to be opened. We explain that decision in more detail here—full disclosure, this is our own guide: https://www.bluev8.com/blogs/news/do-you-actually-need-an-afm-disabler   One exception: some 2021 L82/L84 trucks have RPO YK9, meaning cylinder deactivation was already disabled in the factory ECM; on those trucks a plug-in disabler is redundant, although the AFM/DFM hardware remains inside the engine.
    • Brought my 2015 Colorado into the dealership to check my touch screen issues, had that ghost touch thing happening. They said I needed a new touch screen and they could either order me one for $500. The lady at the service deck was nice enough to tell me I could order a touch screen online for less, she did stipulate that the touch screen had to be factory OEM, you can't pair an aftermarket screen to my radio seeing it was 2015, it had to be a GM factory OEM only. I found a few on Amazon and Ebay by the numbers on the back of the old screen, DJ080PA-01A GM# 22740886, Some said "OEM" in the description and others just said "Replacement". Would a replacement be the same as a OEM as long as it had the same numbers on the back of the screen? In some of the descriptions they also show different brand names but same numbers, is that an issue?
    • I have both but typically use the 4 legged walker (wheels on front, ski's on back).   The four wheeler is starting to be used on "longer" outdoor walks.  The 4 legged walker is particularly helpful in practicing good walking posture.  Both of my knees are at different stages of recovery and I'm trying to not develop poor habits.  I can actually manage with a cane but it's very difficult not to favor one leg over the other.  My PT recommends I continue with my 4 legged walker for a while.  Yesterday was four weeks since my last knee replacement and I'm excited about my progress to date.  It has been a hell of a rough journey so far but it is exciting to witness  systematic and continuous improvement.  I went for years watching the decline of my "mobility".  It seems that everyday now I am alerting my wife to something I can do now that I couldn't a day or two ago!  I encourage anyone facing the prospect of knee replacement to share any concerns with others who have had the surgery.  It isn't an instant fix but rather is a considerable amount of short term pain for long term gain.  Recovery time and pain levels vary for individuals post surgery but the end results are typically very positive and I've never encountered anyone regretting having had the surgery.
    • The lifter issue can be dealt with by shorter oil changes and quality oil IMO.
    • Got heavy rain, hail and light rain yesterday.
