Rearend Noise Over Bumps
mikedogg
Hello,looking for some help with my 04 4x4 ext.cab z-71 43,000 miles....getting a clunk in the rearend going over bumps more noticeable at slow speeds and when turning on a incline or decline but also going straight,it happens in forward and reverse, also I can hear it if I grab the tire and shake it side to side while it's on the ground....had a dealer look at it during an oilchange the other day and they said normal axle play, I'm not convinced ...also I checked and everything is tight, truck had new monroe reflex shocks this past summer and leafs have the insulator pads so I don't believe it's suspension.....thank you
looking at it during an oil change is and did produce nothing for you.
if you can duplicate it consistantly , go back and ask the shop forman to go on a road test WITH YOU in the truck,and see what they say,
If you can duplicate it by shaking the truck back and forth by one of the rear wheels it is most likely
normal axle play. Never really had any real issues with rear supension noise on these trucks other than
some spring slap noise from missing insulators.
The only other possiblity is weak leaf spring bushings causing the springs and shakles to move around too much.
Thanks guys,I'm gonna have it checked again tomorrow at a different dealership to be sure,it just doesn't sound normal to me having owned this truck for 6+ years
is it like a clunk? if i hit a pothole with one of the rear tires it will make a odd sound..i figured it was the springs bouncing..probably nothen to worry about
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
    • Yes, the key seems to be with the half tons that if it has the Z71, then it definitely has the two speed. What got me was that the two speed AND the lower geared towing package option could not be chosen together the last few years unless it was mated up to the 6.2. Want the 3.0 duramax and 3.73 tow gears ... nope, can't get the two speed transfer case ( neighbor son realized that after he had bought his used 3.0 half ton .. where the frick is the low range ? ! ).    I am still unsure which truck series, the half ton or the HD truck that the original poster is referring to for sure other than yes his question is in the HD section of this forum but that doesn't guarantee the question got asked in the right section.
