Truck Fender Protectors
My white Silverado has what looks like plastic strips on each side of the bed just before the wheel well. I guess they keep rocks from dinging up the fender. Well, the dirt has collected around them and instead of being invisable, you really notice them now.
Can I just peel them off? Will, it cause any problems since the fender sticks out there a little? I do have GM mud flaps and also the GM 6" tube running boards, maybe that will help protect the fender?
Any instructions on how to remove them?
Thanks
I know what you are taking about. I have these on mine and figured it was the 3M protective shields. I am not sure how they peel off but I would recommend replacing them if you ever travel gravel
I wouldn't remove them,But if you want to use a heat gun and heat them up a little to help peel them off,you may have to use some 3M adhesive remover to remove any left over residue.
I dont want to take mine off but i would like something good to clean them with
Still no one has figured this out????? :thumbs:
Still no one has figured this out????? :mad:
I get wax/polish in mine when i detail the truck I always use a small paintbrush but with right firmness with detail spray soaked on it and work it out.
    contrabombarde
    contrabombarde
  • Who's Online   2 Members, 0 Anonymous, 1,140 Guests (See full list)
    • Still looks like a rivet to me in the pics, I don't see a nut and none of the pics show the head of the screw. But if you says so.....
