Best Produst For Scratch/scuff Removing
What is the best product to remove small scratches and scuffs? Just seeing what people have had good results with, thanks
Meguiar's Scratch X is really good. The downside to using it, is that it utilizes diminishing abrasives. This means that if you don't rub it long enough it will leave a have that is very visible in the sunlight. Bet you can't guys how I found that out.
It is really good, but if you are looking to fix something worse than little things you are going to need to move up to something with a little more cut (and a rotary/DA Polisher)
If you have a DA polisher then I recommend going with Meguiar's M205 or M105 if it is really bad. The M105 needs to be followed by M205.
Also these are cutting compounds so they are going to take off any TRUE polish and wax.
For serious issues this is the way to go.
I like poorboys SSR products (1,2,3). Works well.
Check out www.autogeek.net they have a ton of detailing products, so many your head will spin. Their forums are great for advice and info on detailing
Depends on the scratch or scuff...... Post a pic... and can you snag your fingernail in the scratch??
Jbo
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
