Hello From Ky
hillbilly4u
Been searching for a good forum to join. Have been lurking for a while and this site has a lot of good, usefull discussions and info. A lot more than the others I've visited, so I decided to join up.
Thanks for all the Welcomes. Pics will have to wait for warmer weather. Covered up with mud and road salt from the snows we've been getting.
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
