Tie Rod Change
hey guyz,
I am trying to replace my inner and outer tie rods on my 95'. Here is the thing, i am trying to take the driver side outer tie rod nut off. After i broke the nut loose, the ball started spinning which is not allowing me to loosen the nut anymore, just spins. Any thoughts on how to fix?
Thanks,
Kirk
got the nut off, i placed a jack under the tie rod and jacked it up to cause the ball to stop moving. New problem, i cant unscrew the tie rod from the sleeve. i have been spraying pb blaster on it for about 45 min and still nothing. what should i do?
Thanks,
Kirk
Heat that sucker. Throw some fire on it to see if it will give.
Mine were so corroded that I ended up replacing the inners and outers and added new sleeves. Just seemed easier that way.
i have been thinking about doing that. problem is i cant get the inner tie rod out on both sides. this is my first full size and idk if the tie rod sleeve is as long as the one i have(4" lift kit). thats why i havnt done it yet. i have a pickle-fork but it isnt working. thanks for the input, i might try that but i need to get the inners out.
Kirk
