Wheel For A 2004 Avalanche
hfuller3
I need some understand or some direction to purchase wheels that I like. I have some after-market 20's and the are under the fenders. I like the wheel and tire to come out from under the truck.
I use to have a 1998 with 15 X 10 with 32 11.50 and it was prefect for me (the look was prefect for me)
I have looked and looked trying to find a 20's that comes out about 2 to 3 inches
I would even put 18's on it but I want the wheel spaced out from the truck.
I don't have a lift and i am not going to put one on it.
any ideals
any ideals
Think twice about doing an offset to the outside like you talked about. The wheel bearings in these Chevys will not live long at all with an offset like that. Do a search and find yourself amazed at all the wheel bearings getting replaced.
Another thing which won't live long are the already weak tie rods and various other links. I'm thinking maybe 50-60K tops with larger (heavier) tire wheel combo. All I did on my 04 Suburban was to crank the front an inch or two and by 60K, the idler link and tie rods were gone. By 120K, they were worn out again!
Tell you what looks really good, and that is the GMT900 series 20" factory chevy spoke wheels found on the SUV's and 1500 trucks. I like those a bunch, they look great, have the correct offset and will work with your factory stuff.
I'm using the factory Caddy 22's which I like, but am changing to a lighter more road racier looking wheel by summer. Maybe try to find a member who is upgrading and grab his take-off wheels...
    • Indeed a proper drain tap or drain valve with adapter that has a hose on it that opens up the valve as the adapter goes on is a slick setup and have that for certain highway tractors etc and other equipment that came from the factory with a tap but this L8T is pretty darned good other than me doing it on the floor and easy to touch hot exhaust and am not as agile as I used to be !. If I really want to pull a hot filter on an engine I will use an insulated set of thick neoprene gauntlet gloves but I am not in the hurry I used to need to be so things are done more relaxed and in theory somewhat safer ... I think LOL.    And as I mentioned the unique shape of the Amsoil 1 quart containers, while they might not work as well as an offset pour spout container for some awkward engine location applications, they are working a lot better with my Lisle funnel kit because of how they prop up on all four corners when upside down resting on the rim of the funnel where the typical quart container would never stay put without holding onto it.
    • Well, I just hit 100K a few weeks back, and I can honestly say I have not had any major issues with my '21 5.3 Crew cab.  I have done most routine maintenance, oil changes, air filter, tire rotations, and a transmission drain and filter change (not even a full flush).  A couple of months ago, I started experiencing the dreaded CLUNK when coming to a stop, sometimes hard enough to literally push the truck forward! After researching here and in other forums/youtube videos, etc, I was thinking it's the slip yoke. I finally had a chance to take it to my local mechanic today, and he was not able to recreate the issue.  Amazing, since it does it nearly every time I drive.  He also said he can't simply grease my slip yoke/driveshaft splines, because I have a 1 piece driveshaft.  I am not sure what else I can do.  Has anyone else had this issue or have any idea what else it could be?
    • This is where the Fumoto drain valve comes in handy.  No mess and able to change oil hot, like right off the interstate hot.  Flows nice and you can direct it into a container. As for the oil filter, I use an old dixie cup or plastic one from McDonalds. It contains the oil as you pull the filter down and not all over your hand.
    • Well, if it did change from lifters to rocker arms, at least it would be easier to fix as they fail.
    • Doesn't hurt to try.  It's my understanding that you have to run it at least 4 or 5 oil changes for things to get clean.  Think about it, your engine didn't get dirty in just an oil change so over time it will slowly clean. It's the safest way to do it and not have seal issues.      I remember  a product that came out a long time ago, AutoRX, it was an additive you put in the oil and then drove for 3k miles. Some saw improvements and some didn't. It was suggested to use a non synthetic with it at the time. Same observation, use a couple oil changes and give it time to work. It also stated it worked best if you could drive on trips to keep the oil hot.  I'm sure if you ask AI it could tell you all about it.
