I just bought a 99 S-10 2 door. The heat is a little freaky. the air always blows, but sometimes it is hot, sometimes it is warm, and sometimes it is cold. I know the water is circulating, I know the air is blowing. I think that the door to the heater core is not opening to allow the air to pass. has anyone else had this problem or could help me with this?
Check the temperature of both heater hoses where they go into the heater core, under the hood, after the truck is up to operating temp. They should both be hot. Even so, these trucks had HUGE issues with plugging heater cores.
A good coolant system flush and back flushing the heater core usually solves it. Sometimes, the core needs to be
replaced because it is just plugged up too much, also.
    • "Life is getting back to normal."    I'm driving again and all new joints are operating as expected for this stage of recovery.   My most recent joint replacement still requires a lot of attention but experience has taught me that time will quiet the remaining pain.  I joked with my surgeon that another joint replacement would take my mind off my most recent surgery and he responded by saying the next will be a hip!  There are no plans for another surgery but, unlike me, I don't think he was joking!  I certainly wouldn't refuse further replacement  if required but hope to spend time out of the "post-op"  period.  I can't stress enough that if you have been recommended for total hip, knee or shoulder replacement that you welcome the offer.  Post-op "recovery" may sound daunting and painful, however, this is far better than the insidious erosion of mobility you are currently experiencing.  Imagine what it would feel like to wake up most mornings feeling better and more mobile than you did the previous day!  Prior to my first surgery in June 2025, even getting out of bed was becoming a formidable task.  Since the day after my first surgery, I get out of bed everyday easily and unassisted.  Making the switch to feeling a little better each day rather than a little worse, is hugely motivating!
    • I get it, Bad Bunny is huge but not everyone knows him The generational gap in music taste is real At least the show will be lively
