What Wheels On A Silver Truck?
AustinZ71
Not gonna make another what wheels should I get but rather, what finish should I get.
Truck is a 2010 Pure Silver Sierra crew cab.
I plan on eventually lifting her 4-6" and want to run a 20" wheel.
What would look better on a Silver truck?
Black
Chrome
Silver (Machined)
I'm diggin the Ballistic "Jester" wheel in black with the trim painted silver.
Chrome or machined. I don't like my trucks to stick out too much. One guy here has stock aluminum 20's from a gmc powdercoated black. They are way cool.
I'm probably going to go with black wheels. But unless I'm mistaken, my "silver" truck isn't quite as silver as yours. Mine's closer to a metallic tan. Ryan posted an image of both Pure Silver and whatever silver is on my truck, and it's pretty different when they're right next to each other.
    President Roberto
    President Roberto
  • Who's Online   2 Members, 0 Anonymous, 699 Guests (See full list)
