Closest Size?
thebandnerd03
I have a 89 GMC k2500. Right now i have 305/70/16 (I know odd size) i was wondering if anyone out there knew of any tires that were close to this size. i like the size but am looking for something that is a little more conventional for a size. I have some 33s but would hate to go back to 15" rims.
Actually 305/70R16 is a very common size. It is equivilant to 33x12.50
