2wd Leveling
I have a 2004 Silverado that I would like to bring up the front end to level it with the back. Has anyone done this and how did you do it? Pleased with the results? Like to do it inexpensively but right.
Welcome to the site. If your truck has struts, you should be able to use spacers under them or over them to achieve the lift. If you have torsion bars, you can crank them for about 2" of lift without issue. Just remember to get an alignment afterward.
It has neither as it is a 2004. It has coil springs. I had thought about the spacers , just concerned it will throw the geometry off a tad.
You could also lower the rear 2" using drop shackles.
Thought about that but would rather bring up the front.
    mdh1053
    mdh1053
  • Who's Online   5 Members, 0 Anonymous, 1,372 Guests (See full list)
