2003 1500hd's Power Seat Up-n-down....
What the heck?!?!? When adjusting the front of the seat cusion up or down the seat moves in the opposite direction of the switch. Press up and it goes down! Press down and the crazy thing moves up. Anyone else seen this? Also (and this may be my imagination) it seems that this adjustment does not have the full range of travel I remember.
Is this a "programming" issue or is there some mechanical snafu at work here?
Programming issue! Seen it before. Take it to the dealer and have them reprogram the drivers seat module.
#PIT3598: Power Seat Switch Works in the Opposite Direction - keywords AN3 driver electrical intermittent memory module move operation recall reverse RKE - (May 26, 2005)
Subject:Power Seat Switch Works in the Opposite Direction
Models:2003-2005 Cadillac Escalade, Escalade ESV, Escalade EXT
2003-2005 Chevrolet Avalanche, Silverado, Suburban, Tahoe
2003-2005 GMC Sierra, Yukon, Yukon XL, Yukon Denali
with Seat, Front Individual (Non BKT) (RPO AN3)
2003-2005 HUMMER H2
with Seat, Front Bucket Deluxe (RPO AR9)
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
<A href="#ss1-1665575">
Condition/Concern:
Some customers may state that the Power Seat Switch will work in the opposite direction.
Example: The customer will move the switch forward and the seat will go backwards.
<A href="#ss2-1665575">
Recommendation/Instructions:
Do not replace the memory seat module or switch the wiring at the Power Seat Switch. A software anomaly exists with the memory seat module. Reprogram the driver seat module with updated software in Bulletin # 04-08-50-016B to resolve this concern.
Please follow this diagnosis process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
