Block Heater Installation
6mmhunter
I have a 2007 Chevrolet Silverado LTZ with a 5.3L. It's the new body style. I imported the truck from the US and it doesn't have a block heater. I was going to install one but was wondering on the location to install. Is it the hex plug on the drivers side front of the block? Also I was reading about the e-plug (the one with the temperature sensor in the plug) Can you just use a standard block heater cord so that the block heater runs all of the time when it is plugged in? I've read that it could possibly trip a service cord but was wondering if anyone on here has tried it and if so what was your experience in doing so. Thanks in advance for your help.
i'd pay the 1 hr labour if i were you,PITA,getting soaked,let a tech do it
my 2 cents
jobber block heaters should come with a real cord,not sure what code(i think you meant) would trip by warming up the block,
i dont know the location,i never had to look lol
