Do Wider Tires Prevent Road Rash?
JB Z71
If I put a 285 55 20 instead of 275's will that help stop road rash on my rims. It is only 10 millimeters, correct? Or is that negligable, would you just stick with stock tires?
I have oem 20's on the way but need tires....
Still waiting for gsx2004 ro post up some pics of his 275 60 20s on the same rims. Man that must be one LONG ass play!
Just to be picky, it is 5mm difference. The other 5mm is on the inside edge. Some tires have an extra strip on the sidewall that is supposed to help protect the rim, but, if you are an inch past the curb, no tire will protect the rim. Best protection besides not hitting the curb in the first place is to use a very tall tire and small rim combo. 35's on a 17 inch rim for example. That gets your rim about 8 to 9 inches off the ground.
"5mm difference" that's a good point. THat isn't much of a cushion on 4000lbs dfitfting up against concrete. They are new and was hoping to keep them that way. As I've been looking at them on other trucks I notice some rash on the rims. Probably that 55 tire isn't helping. They havn't arrived yet, so I have a few more days to make up my mind! Maybe I'll go with the 275 60 20's
    • Indeed a proper drain tap or drain valve with adapter that has a hose on it that opens up the valve as the adapter goes on is a slick setup and have that for certain highway tractors etc and other equipment that came from the factory with a tap but this L8T is pretty darned good other than me doing it on the floor and easy to touch hot exhaust and am not as agile as I used to be !. If I really want to pull a hot filter on an engine I will use an insulated set of thick neoprene gauntlet gloves but I am not in the hurry I used to need to be so things are done more relaxed and in theory somewhat safer ... I think LOL.    And as I mentioned the unique shape of the Amsoil 1 quart containers, while they might not work as well as an offset pour spout container for some awkward engine location applications, they are working a lot better with my Lisle funnel kit because of how they prop up on all four corners when upside down resting on the rim of the funnel where the typical quart container would never stay put without holding onto it.
    • Well, I just hit 100K a few weeks back, and I can honestly say I have not had any major issues with my '21 5.3 Crew cab.  I have done most routine maintenance, oil changes, air filter, tire rotations, and a transmission drain and filter change (not even a full flush).  A couple of months ago, I started experiencing the dreaded CLUNK when coming to a stop, sometimes hard enough to literally push the truck forward! After researching here and in other forums/youtube videos, etc, I was thinking it's the slip yoke. I finally had a chance to take it to my local mechanic today, and he was not able to recreate the issue.  Amazing, since it does it nearly every time I drive.  He also said he can't simply grease my slip yoke/driveshaft splines, because I have a 1 piece driveshaft.  I am not sure what else I can do.  Has anyone else had this issue or have any idea what else it could be?
    • This is where the Fumoto drain valve comes in handy.  No mess and able to change oil hot, like right off the interstate hot.  Flows nice and you can direct it into a container. As for the oil filter, I use an old dixie cup or plastic one from McDonalds. It contains the oil as you pull the filter down and not all over your hand.
    • Well, if it did change from lifters to rocker arms, at least it would be easier to fix as they fail.
    • Doesn't hurt to try.  It's my understanding that you have to run it at least 4 or 5 oil changes for things to get clean.  Think about it, your engine didn't get dirty in just an oil change so over time it will slowly clean. It's the safest way to do it and not have seal issues.      I remember  a product that came out a long time ago, AutoRX, it was an additive you put in the oil and then drove for 3k miles. Some saw improvements and some didn't. It was suggested to use a non synthetic with it at the time. Same observation, use a couple oil changes and give it time to work. It also stated it worked best if you could drive on trips to keep the oil hot.  I'm sure if you ask AI it could tell you all about it.
