1999 Sierra Transmission
I have a 99 Gmc Sierra 1500 with the 5.3L. I went to back up the other day and i have no reverse, it sometimes will move like 2 inches but usually wont move at all, it will just rev up like being in neutral. I have all the other gears except for reverse. I was wondering if I can still drive it or will that make it worse and also what could be the problem. Do i have to rebuild the tranny? Get a new one? Just put new reverse clutches in it? Any suggestions will be great. thanks
WELCOME TO THE SITE....
... if lack of REVERSE is the only issue, then you may not need a total rebuild ... this can be caused by fluid leak in the reverse apply circuit, or also from a worn boost valve ...
on the other hand .. it could be serious... could be worn out LO-Reverse clutches ... and/or cracked sunshell...
take it to someone who can sort out any trouble codes and check it over for you....
if it needs a total fix.... options include
- total transmission and torque converter rebuild with some basic upgrade parts (if you can find a local shop you trust).... or
- GM sells and installs (through dealers) rebuilt transmissions with a 3yr warranty ... this is good value if you can't a local rebuilder
- I would not recommend looking for a transmission from a wrecker... you might end up with one just like the one you are getting rid of
These 4L60E transmissions do wear out and need rebuilding routinely ... commonly good for 130,000 to 150,000 miles ... if you have more than that on your odometer then you already got a bonus.
I am really confused now about my transmission...I went to try reverse and it works now. It works just like it did before and I dont know why it is now working. It sat for like 3-4 days before i tried it. :confused:
How many miles on the trans? Sounds like you may have had something blocking the fluid. Have you flushed it out at all? Is the fluid at it's proper level? Seems after it sat, something went back to normal or all the fluid was where it needed to be....
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
