04 Silverado Transfer Case
So, I have a 2004 silverado 2500HD crew cab 6.0L 4X4 auto trans, manual shift transfer case.
found my transfer case lost all its fluid & tore some stuff up. I took it to a reputable transmission shop for a rebuild. After putting it back together there was a growling sound that he wasn't satisfied with. He took it apart again & inspected everything & couldn't find the problem.
It's now back together and I'm driving it, 4WD is working, but here's the symptoms:
slight ticking/grinding sound in 2H, gets louder in 4H (seems to be resonating up through the floor shifter)
Now, the N & 4L positions on the transfer case is where things get hairy. While the truck is idling in neutral, trying to shift the transfer case into N is about impossible, it grinds like crazy. Turn the ignition off & the grinding will stop & allow you to shift between N & 4L but it does take some finagling. It seems that none of the transfer case shifting, although working, is nearly as smooth as it used to be. Hopefully I explained it well enough, sorry for the long read. Thanks for any & all help!!!
Sounds like a problem with the shift synchronizer. +1 on taking it back and get it fixed. If they can't fix it, have them take it to the dealer and have them pay the bill.
It can't grind going into neutral, there is nothing to grind on. They messed something up with shift system.
weird, because it does. it started doing this right before i took it in for repair. I guess I thought it was all part
of the same problem.
The noise while driving seems to be getting quieter, any chance it's fixing itself? haha
I also found if I do the shifting between 4L & N while the tranny's in neutral, at a slow roll, under 3mph (per manual)
I don't have the grinding, or not nearly as bad anyway. So maybe it is a synchronizer issue?
Like I said, this guy is pretty reputable & he's willing to fix it, just thought I'd try to pinpoint the culprit before I take it back, it sucks being without a truck.
