Hello All..
phase4
Long time lurker & finally joined.
Seems like a great place with a wealth of info.
Picked up a '10 Silverado LT back in late Oct & enjoying the heck out of it.
Big thanks to Matt for answering my Tire ?
Dude knows his rubbers.
:sigh:
Really......... an OU fan? :P
anyway...... welcome! :D tons of guys on here that know their stuff......
But yes we need pics :sigh:
    Brendan C
    Brendan C
  • Who's Online   4 Members, 1 Anonymous, 1,194 Guests (See full list)
