Navagation Unit Question
Hi Guys,
As some of you might remember, I bought a new 2010 1500 4X4 Silverado Z-71 LTZ CC/SB in Victory Red. My truck came pretty well loaded; Convenience Package, Off Road Suspension Package, LTZ Plus Package, Rear Vision Camera System, Trailer Brake Controller, 18" Wheels, etc.
About the only things missing from our new rig is the sunroof, which I didn't want anyway and the Navagation Unit.
My question is this: What would it run to have my local Chevy Garage supply and do the install on an OEM Navigation unit?
I guess I should mention that my Chevy Garage has a really wonderful service department.
Also, my truck has the one-CD player unit. Frankly, I use the UBS thumb memory gizzy for my tunes (can you imagine a 68-year old geezer really LOVING the UBS flash memory thingie?).
By the way, I've owned my new truck since last April and it's been frackin' flawless. It's Victory Red and I love everything about it. BUT, I kind would like a Nav Unit.
Or maybe the OnStar Turn-By-Turn could work instead of. It's only an extra $100 a year ... Is this a viable option????
Thanks for your information and advice in advance.
Steve
I think the unit itself is about $2500 plus an hour or so labor. Plus the antena and vss harness. I would rather have the nav system. But that's just me. You need to decide the best solution for you.
I have the factory nav system and don't like it. Some of the info on my new disc is 5 years old. It trys to take you through every town you go by. And it was way over priced. You can get a very nice hand held unit for a whole lot less. The hand held should have a lot more points of interest on it and I think some of them can be updated on the net for free.
Hi Guys,
Steve
Find a unit from a source other than the dealer. When I get "used" (a lot of times 100 miles or less) 2010+ USB units we get about $1200 for them. You can find it cheaper if you wanted to mess around on eBay or the buy / sell forum here or other truck forum. Just make sure to get a VSS wire and make sure that your service department has programmed one before. Even if they're the nicest guys in the world and you buy it directly from them for full price, you can run into a nightmare with the programming if they don't know what they're doing.
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
