Hello everyone, new to the board but in need of some advice. Last night, I changed out the pass rear shock that was leaking on my wife's '08 Yukon 2WD SLT (no upgraded suspension package). I only had time for 1 and the install went on without a hitch. When I turned on the truck, the ABS light is on, Stabilitrak "needs service" and tractioncontrol is off and needs service. I replaced "dummy" factory shocks with Monroes. There were no electronic connections of any kind and only 2 bolts for the entire install. What the heck happened along the way?
I am thinking that since I only changed 1 the ride level could be off and that would throw the stabilitrak, but the ABS makes no sense to me. Any help is GREATLY appreciated.
I don't think any part of the leveling would have caused the warning lights. I think its more probable, that there is a sensor that is disconnected dealing with ABS.
Shocks wouldn't of caused that issue, I think its a coincident. Have you tried disconnecting the neg side of the battery to reset the ECM?
So the truck has rear leveling suspension and/or electronic suspension control?? Either way, that wouldn't net you a service STABILITY or TRACTION light unless you damaged the wiring going to the rear wheel speed sensor that is in the axle tube near the brake rotor. If it DOES have leveling or electronic suspension, you'd have a service SUSPENSION system message and yes, that could be easily caused by replacing the shock. Need more info.
Thanks for the help so far guys. I did not disconnect anything other than the shock itself other than the plastic wheel well cover. I didn't even remove the tire. There were 2 sets of wires that laid across the top of the frame where the upper bolt is but I do not believe that I damaged those at all. The truck has 45K on it and has never had warning lights before. It made no sense to me. One other idea I had was RF sensors. I know there are a lot of components (in various objects) that have RF sensors and I was thinking that if the factory shocks had these that could throw the warnings. Other than that, I'll disconnect the battery and go from there.
my guess would be they're unrelated, unless you accidentally knocked one of the wires loose.
For $hits and giggles, put the old shocks in and see what happens.....but I'm 99% sure it has nothing to do with shocks at this point
Just wanted to say thanks to everyone who answered, its refreshing to hit up a new board and get pretty good feedback so quickly. I'll post what I find out.
Have you tried driving it? Is the anti-lock doing anything goofy?
Before taking the shocks on and off again-I'd recommend these "shot in the dark" attempts first-
1. Disconnect battery to allow ECM to reset
2. Take THAT wheel off, and see if any wires are loose or disconnected
3. Get the code read
Hearing that you had wheel well liners you pulled and replaced, is making me more comfortable in guessing that you bumped some connection for the ABS, where it connects right by the wheel.
Edited by Metro12
I drove it last night but it was too late to take it to Autozone for them to read the codes. It drove fine, brakes work as usual. Only real difference was the feel of having a functional shock. As far as ABS wiring goes, are they just standard plugs that terminate at the wheels? ABS was what made me nervous and I'm not super sure what I'm looking for other than damaged wiring. Thanks.
I had those same lights come on in my truck a while back and it ended up being a wheel speed sensor that was bad. That would be my guess, and that it is unrelated to your changing the shocks.
If it was a vehicle speed sensor, you would more then likely get a pulsation and delay in the brakes, the last 10ft before stopping. It would feel like you were stopping on ice. (When a VSS is bad, faulty, or not reading correctly, the ABS thinks the wheel is spinning at a different speed when braking, like when on ice and one wheel may lock and the others spin-which triggers your ABS to kick in.)
I'd take the wheel off, and just follow all the wires to connectors, and make sure they are all seated properly.
Edited by Metro12
should be delphi-style connectors clipped into the framerails above the axle... they run down from the frame to the axle, clip to the tube then run into the back of the brake assembly...just look and make sure the connectors are seated properly at the frame.
  • 3 months later...
Any update on what the root cause of this issue was. I have the exact same problem. Changed the rear shocks and got stabilitrack/ABS message when I started the vehicle. There doesn't seem to be anything special about the shocks unless there is some RF sensor installed in the OEM shocks.
+1
Either wiring to the sensor or sensor. Not related to the shock change unless the wiring you moved was speed sensor wires and they got messed up or maybe were partly damaged already and moving them 'finished the damage'.
If it throws the 'service' warnings, the ABS is disabled, so you won't feel the pulsation mentioned by Metro12 at low speeds.
    • I’m out of ideas on this truck. 2020 Silverado 1500. 5.3 135,000 miles. Has a p0308 and p050d codes. Smokes From exhaust when cold. Compression test passed. New plugs, wires and coil on cyl 8. Same issue. New coil on 8, no change. Replaced injectors, no change. Bore scope showed oil pooled on the piston after sitting overnight. Pulled head and had machine shop check it out. No cracks. Stem seals looked good, replaced anyways. He also ground valve seats. Put it all back together and still have the same issue. Bore scope shows oil on the piston again. Leaning towards maybe a cracked ring but unsure. Cylinder looked good when the head was off, no scoring or scratches. Any ideas on what else I should look for?  Appreciate the help
    • Just want to make sure it is covered by Special Coverage N232395310 Evaporative Emission Purge Pump 2021 Silverado 1500 Custom 2.7L L3B ~100k miles I'm getting DTCs P146B and P146F. VIN 3GCPWBEK2MGxxxxxx   I spoke to a person that works at GM and he said it is not covered after checking my VIN.   Is there anyone here who currently works for a GM/Chevrolet dealership and has access to GM Global Warranty Management / Investigate Vehicle History who could explain how the VIN eligibility is determined?   thank you
    • Thanks for all that information, I might purchase one and see if it will work for me, if not they may let me return it! Yes for sure the tires are definitely within limit for my truck empty, and when I do tow I'll definitely make sure to raise the rear psi for the amount of weight that's going to be on it.
    • Yes exactly, more and more these days people/companies are afraid of liability issues so its easier just to say no rather than risk putting their neck on the line.    I will say with the Autel unit or when I used it last year on my truck, it wasn't like I could choose the 2025 model year or even the 2024 model year as that option was not there to manipulate the placard pressures but had to go back to 2023 or there abouts and then it showed up as an option, odd but that was how the software was then and I can't say one way or the other now as they throw out updates every so often. I still would talk to your tire dealer though to start with and they may do it for nothing but also they may have a comment on a better unit to purchase. All I know is that one of the large tire shops in my area happens to use these Autel units for their use and set them up to use the wifi and all of that jazz for constant updating because each tire tech has one handed to them by the shop but I just plugged it into my laptop to update it and yes if one is bought it has to be registered so you can get the link to do updates and then the unit has to be updated before its even used. I am not at all techy so it took me a bit but anyway just a heads up for anything you buy, most likely it will need to be connected to a computer to access the internet to have it updated to the latest software version before you can put it to use.   If your truck is near empty, those tire pressures you listed are a very safe upper range pressures to carry the weight, both the front and rear as I know they could be run lower yet with an empty truck. And if its a trailer and not some motorcycle your going to strap onto the front of your truck on a rack, you shouldn't have a need to inflate your front tires if your at 55 front already, its the rear ones that would need more air if you have much hitch weight.
    • Thank you, I'll check that Autel scanner out and see if it will work for me! Ya I can see GM's point of view if they lower the psi set value for someone and the person sell's the truck and the new owner puts the factory tires back on then their could be liability issues cause the psi warning light wasn't coming on when the tires were under inflated for towing their load and then it might be able to be traced back to GM lowering it.
