Turning On Factory Nav Rearview Camera
Obviously it comes on when you put the truck in reverse. Is there anyway to wire it to a switch so you can turn it on any time you want?
My wife needed to go somewhere last night and it was snowing pretty good, so she took my truck. Some jerk in a 4x4 was riding her bumper on a two lane road. She called me to ask if she should pull over and let him go around, I said "hell no" now days you can't trust that its not some nut job. If there was some lighted parking lot that would be different but this is a dark two lane road with not a lot of people around. Considering the 6-8" of new snow she was going plenty fast, I don't know what his problem was. He was obviously messing around, he would fall back and then run up within a few feet of her. I told her to call the cops and tell them where she was and what was going on. While she was on the phone with them he turned off. They told her they had several other complaints that were similar. It sure would have been nice to turn the camera on and get his license plate number.
I'm no electrical expert, but I would think it wouldn't be to hard to wire it to a switch. Has anyone done this?
    • Hey guys, sorry for the confusison about this. This wasn't my experainnce, it was copied and pasted fom the net.
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
