Replacing Bcm With Used One
baba08
hi
i have a gmc savana 2500 VIN # 1GCGG25V831125353.and have bcm problem.and i found used one.but used one is off 2006 CHEVROLET EXPRESS G1500 VIN # 1GCFG15X761167010.can i plug and play or i have to program it.can i program the passkey to it with out using any scan tool.would it work.if i plug it would it cause any damage to anything. i called the dealer and he gave me part number,then i called wreckers the part number they gave matches the dealer part number
part # of my bcm is 15194169
dealer part number is 10367689
used bcm part number is 10367689
thank you guys
hi
thank you guys
You will have to have the RPO configurations programmed at the dealer, a Tech-2 alone will not do it. The scan tool needs to be connected to a techline terminal to have those things programmed in.
If you want you can learn the security yourself. I suggest a battery charger as you will have the key on for a half hour total and if you loose battery power you could be S.O.L.
Turn ON the ignition, with the engine OFF.
Attempt to start the engine, then release the key to ON; the vehicle will not start.
Observe the SECURITY telltale. After approximately 10 minutes, the telltale will turn OFF.
Turn OFF the ignition, and wait 5 seconds.
Repeat steps 1 through 4 two more times for a total of 3 cycles/30 minutes. The vehicle is now ready to relearn the Passlock™ Sensor Data Code and/or passwords on the next ignition switch transition from OFF to CRANK.
The vehicle learns the Passlock™ Sensor Data Code and/or password on the next ignition switch transition from OFF to CRANK. You must turn the ignition OFF before attempting to start the vehicle.
Start the engine. The vehicle has now learned the Passlock™ Sensor Data Code and/or password.
