2011 New Engine Oil For Gas Motors ?
racerhog
Ok...I just got told that 2011 all GM gas motors need a different engine oil?
Whats this all about Guy's
Hope some of you GM guy's will shine a little light on whats up?????
fyi..................
The Federal Trade Commission (FTC) recently issued a consumer alert clarifying that the Magnuson-Moss Warranty Act prohibits automobile manufacturers and dealers from denying warranty coverage based on use of an aftermarket product, unless they can show the product caused the damage or was installed incorrectly.
“The FTC’s statement should help those ILMA members, for example, who have decided not to license General Motors’ dexos™ engine oil,” said ILMA counsel Jeff Leiter. “Some ILMA members have complained to me that the automaker has made confusing statements about its new engine oil and warranty coverage for new vehicles. It makes sense to hand a customer a copy of the FTC consumer alert, showing that the use of equivalent products should not affect warranty coverage.”
The FTC consumer alert can be viewed at http://www.ftc.gov/bcp/edu/pubs/consumer/alerts/alt192.shtm.
.. do you really want to have all that hassle with a dealer over your warranty on a 2011 new truck..
.. maybe you could fight it and win your warranty coverage back... but who wants the stress?????
.. just use Mobil1 ... it is on GM's approved dexos list .. I am not promoting this oil and I don't use Mobile1 right now, but I would have no problem switching to it if it meant preserving my warranty
.. I don't necessarily agree wit this kind of business practice, but if I bought a new 2011 I would follow the warranty requirements ... if I truly thought it was total bs then I would buy a used truck ... or another brand... of truck
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
    • Yes, the key seems to be with the half tons that if it has the Z71, then it definitely has the two speed. What got me was that the two speed AND the lower geared towing package option could not be chosen together the last few years unless it was mated up to the 6.2. Want the 3.0 duramax and 3.73 tow gears ... nope, can't get the two speed transfer case ( neighbor son realized that after he had bought his used 3.0 half ton .. where the frick is the low range ? ! ).    I am still unsure which truck series, the half ton or the HD truck that the original poster is referring to for sure other than yes his question is in the HD section of this forum but that doesn't guarantee the question got asked in the right section.
