Engine Swap In A 1992 S-10 Tahoe
bcoop713
I have a 1992 S-10 Tahoe 4WD 4DR original engine was a 4.3 it now has a 350 and transmission from a 1992 C1500. I'm having trouble with the speedometer only showing 1 mph when I'm going 20mph, 2 mph for 40 mph, and 4 mph for 60 mph. I know that the original transmission sensor was probably on the transfer case not the trans housing. I just purchased the truck and am trying to find the best solution to fix the gauge so it will read correctly. Could it be a sensor between the dash and trans, or could it be that because it was 4WD and is now 2WD that it could be incompatible with my gauge cluster? I'm not a mechanic by anymeans so any help would be great.
You'd probably be better off contacting these guys: http://www.transmissioncenter.net/performance_automotive.htm
This forum is more for factory stock OEM questions.
There are color coded plastic gears in the tranny for the speedometer drive -- they have to be the correct ratio for your truck. You'll probably need to know tire diameter & rearend ratio before calling. That place has everything you need - they specialize in overdrive transmissions.
EDIT: If you scroll waaaay down that page - about 3/4 the way down, there's a speedometer gear chart plus a speedometer gear calculator. That should get you what you need.
