Tires And Wheels
monkio
Hey everyone. I'm a newbie to this forum so please bear with me.
My truck is a 2010 Chevy Silverado crew 2wd and am wanting to put rims and tires. I like the oversized look so I am looking for a tire that will sit about 2 inches outside the wheelwell. The tire I want is 285/60 18 on a 9 inch wheel. What I would like to try to find out is the correct backspacing and offset as not to rub the wheelwell. Any help would be appreciated. The front has the 2" leveling btw.
It's not going to happen. In order to achieve the look you're after, you need a wheel with about 4.5" of backspacing and maybe even a wider tire. Needless to say, that setup would rub considerably.
need more lift.
like the others said you will need a bigger lift. Do not put on wheel spacers as they can be illegal as they are in my area, and they can damage the axles. And i really hope you are going to put on wider fender flares, because if you don;t you will be repainting your truck in the near future. The tires will throw rocks and stones and chip the paint on the fenders all around the wheel wells.
Even with fender flares I still get rocks and dirt flung up all over my truck.. You would also need to run a mud flap and well they just dont look good. Best thing to do is buy a color that hides chips well..
    • Looking at cheap tires for this project '95 Blazer. I'm seeing all sorts of brands I don't recognize. 235/75/15 are the size I'm after.   "Dirt cheap" (<$100/each) Starfire Solarus (AS or AT) Rocky Mountain HT2  Mohave HT Westlake SU318 H/T Laufenn G FIT Entry Level AS (yes, Entry Level is the name of the brand!)   "Somewhat cheap" (<$150/each but >$100) Kumho Solus TA51a Ironman (Les Schwab) Cooper Discoverer RT AT Hankook Kinergy ST (H735) Milestar Patagonia H/T Toyo Extensa AS II   The only one that stands out is the Cooper Discoverer in looks and actual brand recognition for me. $120/each. The buyer for this truck will probably want a visual look of not a completely smooth car/highway tire and this one has slightly blockier tread.   Starfire is supposedly a sub-brand of Cooper. Mohave is a house brand of Discount Tire. The spelling bugs me, I've always known it as Mojave. Kumho, the name, still makes me giggle.   If I was selling it tomorrow, I'd probably go with anything in the Dirt Cheap category. But I may drive this around through the fall and my mind would be ruined knowing I'm rolling around on "Laufenn" or "Entry Level" tires, name alone.   In a world where *most* tires are now offshore-produced, is one low-buck tire much better than another?
    • Most vehicles have engine covers. The cooling fan’s are below the cover. That probably doesn’t help. I cleaned collector car engines. The rest not so much since the last one protested by missing for a few days drying out.
    • Point of clarification on this graph. It is the life of the FLUID not the Transmission being graphed. Compare to his comments below the graph. Get it to the top of the graph and you can kill one in an afternoon.
    • Did all this valve cover work slow the oil consumption?
