2003 Cigarette/acc Plug Won't Power On
Rosedog
I have a 2003 Silverado and it has two cigarette/acc plugs. The one nearest to the passanger side went out earlier this evening.
I had plugged into it a dash heater, I was testing the heater (brand new). It ran for a few minutes and then it cut out. This heater has an inline fuse but that did not pop.
I tried plugging my radar detector into that socket and nothing. However if I use the cigarette/acc plug on the drivers side it still works.
I checked my fuses on the drivers side and I can't find anything for the cigarette plug fuse. Where is it located? Or is there a fuseable link that I can't see that may be popped?
If I knew how to remove my lower dash I would have done that already but this is annoying enough as it is.
I should also mention that tried a test light on the plug and got nothing.
Fuse is in the fuse box under the hood. Just look in your Owners Manual.
BIG THANKS to you! That was it.
I thought I was going crazy and I got stuck on the first page of the fuses last night swearing up and down that something was wrong.
Thanks again for the pointer!
