Does Anyone Have A Price On This?
I have been looking on ebay for a new dashboard glove compartment door (upper) and I really only find the older versions. Is there a part number? I appreciate any help that you guys can provide.
Is there something wrong with the door or is it just that the handle is "IN"? If it is just the handle leaned in, I went to a junkyard and pulled the little rubber bumper out of a wrecked truck along with a couple for the gas door. I picked up a few other things but they just gave me those bumpers.
Be careful though, the gas door bumpers are not the same size as the glove box bumpers and are a beotch to get out if put them in the wrong place.
The latch broke. I went to the dealer yesterday and they do sell it for $20. I thought I may have to buy the entire door, but they do sell the latch by itself. Order's going in today.
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
    • Yes, the key seems to be with the half tons that if it has the Z71, then it definitely has the two speed. What got me was that the two speed AND the lower geared towing package option could not be chosen together the last few years unless it was mated up to the 6.2. Want the 3.0 duramax and 3.73 tow gears ... nope, can't get the two speed transfer case ( neighbor son realized that after he had bought his used 3.0 half ton .. where the frick is the low range ? ! ).    I am still unsure which truck series, the half ton or the HD truck that the original poster is referring to for sure other than yes his question is in the HD section of this forum but that doesn't guarantee the question got asked in the right section.
