I Can't Believe...
It does look good... I have a 06 Sierra and thinking about removing mine too.. 2 questions... First, what is the purpose of the air dam? and second, how easy is it to remove? is it hard to put back on?
cheers...
I wasn't sure about taking mine off, but after I got it off I was glad I did. It's safely on a shelf in the basement. I figure it was only a matter of time before I drug it in a snowbank or on a high curb. So off it came. I know it's supposed to add to gas mileage, but I haven't seen any difference at all. On the lighter color trucks I think taking it off makes an extreme difference. You don't notice it as much on a darker color like mine, but even on a truck that isn't leveled it makes the front look higher.
cheers...
It def looks a lot better off with the leveling kit. It has that clean look from front to back. Supposedly it offers more MPG, but from what I've read on here people didn't notice a difference. It took all of 10 minutes to undo 2-10mm screws, pop out the plastic pieces, and place on the shelf in my garage.
I took mine off also but in a weird way, I went pretty fast in a snowbank and when I got out, it was there on the ground. So it took 2 minutes to to take it off. :shakehead: And the best thing about that is I didn't broke anything.
cheers...
I agree looks much better with it off. As far as its purpose there are a few topics floating around on these forums that will answer that question pretty thoughly. Guys have had their trucks tested. Not having it gives the truck more drag thus giving you worse gas mileage. But if your worried about gas you shouldnt have got a truck. Here are some before and afters with mine. It makes such a hudge difference.
    • My son got a hatchback withe the aero package for like 17k new. Great little car with amazing MPH
    • Yeah, I've given up years ago with that! I was able to load a few when I first joined the site sometime around '07. Then after maybe 20 pics, it said I exceeded the limit. Now every pic I try to post says I've "exceeded 1mb".   ONE MB??? That's Windows 95 ******, lol!!
    • I get the same results with pictures. Then I figure it out. Then I forget. Screw it.
    • I guess I'm the only one on this forum who can't get effing pics to load here! Do you have to resize them to post, or am I just blocked from uploads?   I have the same luck with automotive electronics ... but this is the ONLY site on the net that I have this problem!   I'd post pics of what I'm working on ... but I CAN'T! 🤬       Just fabbed up the kickdown cable (had to extend the cable mount WAAAY out from the throttle shaft to get a full pull), and parts arrived for the fuel lines on the 940 carb conversion project. Should be able to drive this thing by the end of the day. If not for work, I'd have had this thing done SIX weeks ago.   Got the jetting sorted out last week. Had a real bad tip-in bog that I couldn't seem to correct. Friggin float height was over 11mm too HIGH! eBay purchase, so no wonder everything is screwed up right out of the box! I ended up with a larger dual-squirt accelerator pump jet anyway instead of the single. Also moved the 70 primary idle jet (4 sizes too big out of the box) to the secondary idle circuit, and installed a 57 in the primary. Runs great on the fuel bottle!    Still using the computer for ignition. Going to drive it first and see if I want to go through the project of installing an intermediate shaft with a distributor drive gear, so I can install a block-mounted distributor and run points, 100% computer free. I should do that anyway just from a simplicity / reliability / tunability standpoint. The electronics left me stranded last year a couple times! I can't tweak the timing to my liking right now because of the computer. Tried twisting the cam-driven distributor already ... and the damned thing just reverts back to where it was! That's infuriating. But if it runs well enough I might save that for next season.   Just driving it in and out of the shop to work on other projects, it feels 1,000% more responsive with the carburetor. Also fires MUCH faster when cranking. Can't wait to drive it and see if I got more than 114 ponies, lolol.   Hopefully these don't go 404 like the last post ... https://postimg.cc/gallery/MjhrmZS   Seems like that site went back to dial-up internet! Maybe they'll fix that some day ...
    • Triumph makes me think of cars not bikes. Especially with model names like the TR7, that was a Triumph car model too. Peak TR for me was the TR250. You could retain the post-war roadster looks, with an optional surrey hard top, but with an inline 6 engine instead of the TR4's anemic 4-cylinder, but still have a 4 speed, optional overdrive.   I know almost nothing about Triumph bikes, except that they exist. Good looking bikes though.   I don't know if I could just have one vehicle. The Silverado does it all except for fitting anywhere. But it leaves a void in real driving enjoyment, unless driving an extremely large sofa is your thing.   What did I do to my 'other' (muslce car - which one!?) vehicle lately. I took my '23 SS for a drive. It's only got 1600 miles. I keep reminding myself I shouldn't be so precious about this car. It likes to be driven. Needs to be driven. Life is short and if I don't enjoy it, someone else will. The other half calls it "the garage ornament".
