Rancho Quick Lift
I have a RC leveling kit for my 2011 silverado that i have not yet installed because i did not want to modify my struts. I was looking at the rancho quick lift shocks as an alternative. Does anyone have any feedback or experience with these?
You dont have to modify the struts with the RC kit, all it is is a block that goes under the strut base to the bottom "A" arm, 2 bolts on each bottom strut. The other brands install on top of the strut and you have to cut down the top strut bolts but not with the RC kit. It tells you in the instructions.
The kit I got for the 2011 installs on top of the strut.
Rough Country? i didnt even know they made an upper leveling kit for 1/2 ton chevys
They don't make one. There is no point why they would make one because the suspension did not change. And the bottom spacer is cheaper than a top spacer
Rough Country
The op either must have a different brand or a rough coutry leveling kit for a Ford, Dodge, Nissan or Toyota.
unless he bought the 3" pos... i believe that goes on top...
The 3" has both the upper and lower... so it's not that. I'm with Nadie it's either for a different truck or its not rough country. possibly TUFF country. Wouldn't be the first time people say Rough instead of Tuff :)
