N.L. GMC Posted March 6, 2011 Posted March 6, 2011 2006 GMC Sierra Hi, I could use some help with this problem.. The HVAC unit on my truck isn't functioning properly. Originally, the fan blower switch didn't function at setting number 5. After removing the hvac panel and re-connecting it, now none of the settings work. No air blowing whatsoever in the cabin now, although the AC button still turns on and off the air compressor. Also, the passenger side climate control switch for adjusting temperature doesn't always light up and can sometimes be turned on by tapping on it.. I've read on another forum that the "Blower motor resistor, and possibly the harness" need to be replaced.. Will replacing these parts fix all my hvac/ ac problems? I need the hvac unit functioning fully and the ac/ heater blowing properly.. thanks
