I have a 2008 1500 4x4 4.3 V6 with 40000miles. Recently the ENGINE HOT A/C TURNED OFF warning pops up, but the engine isnt really hot. It seems to reset itself after a while. I though it did it more in wet weather, but today is dry (though yesterday rained). It did this yesterday. FIrst i disconnected the temp sensor on the left head, then reconnected it. It looked clean. This did nothing. Then, I disconnected the battery, and when i reconnected it 20 min later it was back to normal. I drove about 20 minutes twice today, at the end of the second trip it did it again. There was a recall to remove the insulation from the under seat computer, which i had done. It had the problem prior to this, and still does. Its probably occurred 10 times in the last 6 months, 7-8000 miles.
DO i justs need a temp sensor, or is it possible more involved?
thanks
Sean
thanks
Sean
Do you have a block heater?
no block heater...Connecticut isnt quite that cold.
it did it again. i disconnected the battery for 1 min, and that reset it
  • 5 months later...
This problem is all over the internet but I have yet to see a reasonable fix posted. I see some say to replace the thermostat, but the temperature guage drops to lowest reading instantly, which tells me that the engine temperature is not actually changing. Plus the problem can linger a few days and then the guage will instantly jump to a correct reading and all will be ok, until next time. some have said they have replaced the temperature sensor with no luck. Does anyone know the answer or can they explain how the thermostat can cause this to happen? I am thinking the computer must be involved in this somehow.
If the engine was hot 255F or higher the PCM would have a code and the SES light would have been on. I suspect a electrical problem possibly the cluster. BTW the PCM is not under the seat its in the engine compartment.
I was just going to post the same problem with my buddies 2008 Impala....probably the same issue
Here is my situation. 4.8l v6. 2008. Truck has no issues as long as the outside temp is about about 75*. Once temps go below that I have problems. I leave to go to work and truck has sat all night. Once I drive about 7 miles the temp guage goes from normal to nothing and my A/C wont work. If I disconnect the battery the guage goes back to normal and the A/C works fine until the next morning. Also if I don't disconnect the battery I can get on the highway on the way home and it will start working within 100 yards of the same place every day. I have no problems in the summer, but on the coldest days after sitting all weekend it shows engine hot. It has got to be something to do with the ambient temp.
  • 3 months later...
I have found This is a common problem. GM engineers have apparently decided that if the engine temperature is too low (example 195deg) that they will display "engine too hot turning ac off". I had the same problem and replaced the engine temperature sensor but that didn't fix the problem. I had GM replace the thermostat and that fixed the problem. It doesn't make sense to display this on an engine that is too cool, but that is how it works.
  • 8 months later...
This happened to me three times in my 2008 Silverado (4.3 V6). I took it to the dealer and they replaced the thermostat free of charge under the powertrain warranty. Aggravating, but at least it was a free fix.
  • 3 years later...
I have a 2007 Chevy Silverado, with this same issue, I have changed the thermostat twice and it still keeps happening. Last Thermostat change the error did not happen for a few months but started up again and we finally have cool weather. Stopped unplugging battery to reset and when the weather is cold in the morning the temp guage will start up on it's own again, but the warmer the day gets or the longer drive the truck it comes back on, very annoying any real answers for the fix out there.
I Have the GMC Sierra 3500 HD with a Vortec 6.0L . I've faced this problem well over a year now, and i only encounter its appearance after it rains, while in summer the engine works perfectly. i knew that the problem is back only from the temp gauge going lower to 90 degrees when its normally 100 (Celsius because I'm in Dubai) but i know the normal engine temp is 100. I've changed the thermostat earlier but the problem wasn't fixed, i cleaned out the battery wires after it then the problem was fixed for well over 9 months. And now the problem is back and its taunting me and really really pissing me off. Please HELP me because its my daily driver truck and i just wanna get over with this shit and get it fixed. One trick i keep doing when this appears is that i disconnect the Battery wires and reconnecting again then the problem is fixed for a few hours, then its back again. The temp here in Dubai is over 40 degrees Celsius and i always boil while driving, Hell i even had to do the battery trick even when i was on a date. TWICE for gods sake, she never called again....
Hi everyone,
This is to help whoever can benefit from it.
First my background. 28 years as an ASE Master, L1, CA Smog Tech, B & L Inspector. Been doing this way too long!
This same issue started six months ago on my personal truck but it was very random to say the least. The problem would always disappear by the time I got to my destination until last week. Going by the symptoms, I knew this was a electrical/electronic problem and not a mechanical (thermostat) problem.
My diagnostics lead me to the BCM. Problem is that as soon as I touched the wire harness going to the BCM the fault disappeared and has not returned. I did however unplug and inspect for signs of poor connections and broken wires at the BCM. I have seen way to many times that wires will break inside the insulation due to excessive stress caused by engineers. The harness is very tight going to the BCM connectors. I hope this helps some you and I will add more if my ghost shows up again.
Bought a 2011 Silverado a few months ago, same problem. Changed the thermostat to be certain and there was nothing wrong with it. Now I have a flashcal and I checked the engine temp when this A/C off code came up and the temp is just fine 168 at the moment (even though the needle stays at 0) No other codes or problems. Like you I suspect it's wiring or a connection. Thanks for the heads up, I'm going to see if it's around the BCM as well.
On my way to work I received the same error again. I reached my left foot up behind the dash and tapped a wiring harness and immediately the error disappeared and the gauge went back to normal. Now to figure out which one it was.
Edited by 11BSilverado
    • No doubt... But, as someone who doesn't pay for his services, but who has provided a few views/clicks on his Youtube platform, the data around the Mobil oil testing I think does have some value including to "freeloaders" like me.   A lot of what he's doing is likely showing the OE's work in their oil selection, something that many of us had kind of assumed was true all along, a good balance of both excellent protection and efficiency.
    • Lake Speed is drumming up business for his company just by being in the spot-light so he has a vested interest in stoking the 0W-20 fire.  IMO
    • I knew when I bought my truck that it had off road hill decent or craw control or whatever they call it and rolled my eyes at that but it gets throw on with other options my truck has, I just never had a heads up if the highway speed regular cruise setting had anything to do with the brakes and that took me by surprise. If you've ever been to the top of Pikes Peak and watched those ahead of you on the way down with their brake lights on constantly, one can guess they are probably not gearing down or not enough anyway if their vehicle will allow and a good reason their is a brake check spot part way down where they use an infra red heat gun to check how hot ones brakes are front and rear.    Your right that once one gets out of the front range by Denver and I've not been on that stretch of 285 between Denver and Fairplay myself but I know its high and Fairplay at 10000 feet, Buena Vista at 8000, it drops a bit from there but then your going back up and over the 11000 pass and Durango is at 6500 . So yes your definitely right that 6500 and a lot higher is the theme of going anywhere out in that direction from Denver but hey, the down hill sections give fantastic fuel mileage !.    I don't even look at the fuel pumps for what premium costs here, since I live on a farm and up to this point get fuel delivered I am rarely in front of a fuel pump and when I am, I am often using card lock bulk fuel stations so it tells me what the price is AFTER I buy the fuel. Looking up on gas buddy and converting to US gallons but in Canadian dollars, regular on average of the prices listed was around 5.95 and premium is around 7.00 . That was one reason I did not go for the 6.2 half ton aside from its lack of carrying/towing if one was going by the rule of using premium fuel and until recently one could only buy regular farm gas if playing the few cents off game for farm dyed fuel for a "farm licensed pickup". But yes I hear you on the fuel price difference and like the diesel theme with it often being more expensive then gas it doesn't have quite the charm to it either as it once did although right now here for some reason the price of diesel has come down more so its now inline with the price of regular gas.
    • I agree with this assessment. As you know I’m testing longevity with vehicles for the first time. I have a few vehicles I passed to kids and grandkids. We’re all past 100K miles some approaching 170K. I’m the only one doing 5k oil changes. The rest whatever the minder says. I’m the only one doing frequent transmission service. My odyssey the trip vehicle at 200K will be finished as a trip vehicle. I recently changed to high mileage oil, Valvoline. I can’t get past the fact that all manufacturers want to claim long service life. I just don’t make sense that they would go with low weight oil for mileage. While sacrificing longevity.
    • There's absolutely a mountain of profit in catering to the "I do my own research" crowd, people who are certain they know better. And I don't mean there isn't data to support that 0w40 produces less wear product than 0w20 in an engine like the 3.0 Duramax, that only feeds them the assurance they need. Again, my whole thing with oil selection is, sure, 0w40 or 0w30 produces less wear product. Are we talking the difference between the engine lasting only 100k versus 200k? Or are we talking more like, if the engine will already go 350k on a good 0w20 regimen recommended by the OE, is using 0w40 going to get us to 355k, assuming we can even get the rest of the truck to last that long, meanwhile sacrificing the first 5y, 100k in powertrain warranty. The answer isn't easy, there are tradeoffs.   I willfully use 0w20 Dexos D for this reason, knowing that a 0w40 will produce slightly less wear. I don't believe the delta in wear product is meaningful over the lifetime of the engine, and I place much more importance on driving style and overall feeding and care of the engine as a whole. It's the mentality that someone can abstain from alcohol their whole life which is an amazing boost to health by itself, theoretically. But if they're sedentary, that lifestyle choice will most likely kill them young despite their other, concerted efforts. Maybe someone doesn't drink AND they are the perfect picture of health and activity AND they use 0w40 AND they treat their engine perfectly. If living until 130 years is the goal, sure, do that. But it's going to be a really old truck falling apart around a good engine for that last 30 years, without a doubt.   I watched Demonworks' other video on the 100k+ 3.0 Duramax that had dealer 0w20 changes on what appears to be OLM-prescribed intervals (8-10k).   The QR codes are still present and readable on the main bearings. That's how little wear it has.   That's not proof that anyone else should stick to 0w20, but it's confirmation, for me, that 0w20 is perfectly acceptable to use in these engines.
